Habitation door lock broken ... argh!
We had a similar sort of mishap not too long ago on an AutoSleeper Nuevo - but I think most use a similar system.
My wife slam locked the habitation door with both sets of keys inside. I borrowed a drill and drilled the lock (disappointingly easy) until the barrel literally fell out. A screwdriver sized slot was clear to be seen and a turn with one unlocked / locked the door.
We were able to continue with a plug of BlueTac keeping moisture out and Milenco sold us a replacement lock barrel with 2 keys for about a tenner when we got home. It simply presses in and latches securely in about 10 seconds!
Hope this helps and someone near you has a drill....
Norrie
From the pictures, you have a Zadi lock system. The Key slot on the outside in not in the right position, it should be horizontal or vertical.
I would suggest you need to remove the internal cover on the door to expose the mechanism. It may well be that one of the latch operating bars has sprung loose causing the lock to jam. It is not that difficult to remove the cover. Put up a photo of the internal door with the cover and we might be able to help further.
Ed
Might have no option. We're a bit perplexed now as to what to do anyway, due to the lockdown. Reality is, we've been pretty much self isolating whilst traveling. Don't know if locking down in a motorhome is allowed.
Only if it’s your primary residence? Like the FLT 🤣🤣
If not then you need to get back
the mechanism is metal parts with springs, but let down because the operating rods clip on/off with plastic retainers. All too easy for a rod to come unclipped causing this situation. But relatively simple to fix
YORKIEMAN G-RMPS.
We had a small spring break in side our Hymer. Get some one to take the cover off and have a look in side . The spring is about 1” long and twisted on each end. We got a spare spring from Travelworld for £1.98 YES £1.98 .
even if you can’t take it off get some else to take it off and look and see if it is the spring , easy to fit. I have a photo of the spring some where if you want see it let me know.
Colyboy
Thanks, but I've been inside the lock. The latch has sheared off, the spring is fine. The latch is currently engaged in the door frame so the door is locked, but cannot be opened from outside because pulling the handle does nothing. If I could get a replacement latch it would be an easy fix. Fortunately it broke just as we returned home from 7 weeks away. We can afford to wait for a replacement unit. It's just irritating having to pay £150 for a complete unit, 95 percent of which is redundant. I had thought of trying to get the broken bits welded together, but the van would remain unlocked while the part was being attended to.
Ed
Sorry it's taken me a few days to get back with the photos. I've been on electricity rations as the batteries ran really low. We got a good drive in yesterday so I am back with laptop privileges.
Here's the photos Ed. Any guidence would be awesome as at the moment we are having to shuffle out of the driver or passenger door, which isn't too elegant.
