sparky
My dealer on my last a class ticked the box to say the smoke alarm was working ok on the inspection sheet we don’t have a smoke alarm in the van?
Yeah I agrea, unless you are about to sell, then you can evidence the vans good condition. If not selling, yes a waste of money again unless you are wanting peace of mind.After owning our m/h for 3 years I was persuaded by someone "with experience" that we should have a Hab inspection done as we hadn't already done so. The van is 2004 and as far as I was aware had no problems. So, £120 later I am in possession of a form that says there's no damp, all the appliances work, all the window blinds etc work, there are no gas leaks, the boiler draws x amount of amps and the fridge draws y amount of amps and another numberof other realitively useless facts. I have my own damp meter and a basic multi meter and together with the fact that there has never been a smell of gas I knew all this already!
I'm not saying that the inspection chap did anything wrong but I just feel like an idiot for commissioning the test in the first place. Unless you have to have this done for a manufacturers warranty then I simply don't see the point ( unless of course you cannot be bothered to buy a £15 da mp meter and a £5 multi meter).
Lesson learned though and I won't be bothering again.
I used to belong to an Association, and had similar arrangements, however we were an independent Association.
If you want an electrician to come round to your property, you will have the choice of NAPIT or NCC, does going by what you have commented on, say your house is among that group!! you mention.
I appreciate you have taken the time and trouble to check this out.
Flook
That sort of leak is going to be obvious and only visually which anyone can spot. With vans like Carthago, Hymer, N&B where the inner wall is aluminium its impossible to do a damp check, damp meters don't work on aluminium.Carthago's have the same type of construction but one owner had water ingress from the joint between roof and side wall. It was fairly obvious though, as he had staining on the inner fabric side wall.
Flook, NCC stands for National Caravan Council. I am not sure what that would have to do with electrical work on your house. Perhaps you are confusing it with the NICEIC.
Campirama the Only Hymer dealer.Lenny, where in Belgium do you get your damp check done.
Edit: Comment deleted as dealt with in post #66I used to belong to an Association, and had similar arrangements, however we were an independent Association.
Flook
Only on Brit vans others only need a damp check.To keep warranty valid you have to have it done
So we are still getting ripped off when they insist we pay for a damp check to keep the warranty. At least by getting mine done in Belgium I only pay £60, UK dealers prices vary between £130 to £275.
I think it's similar in Germany, probably because you are not in rip off Britain.Why is it so cheap in Belgium ? Presumably the hourly rate is much less than in the UK .
Because so many Brit van owners are gullible,,BUSBY??Why is it so cheap in Belgium ? Presumably the hourly rate is much less than in the UK .
You only get that problem with Brit vans, German vans don't require a hab check to keep the warranty, rip of britain again.It was eventually sorted and warranty work done but it highlights the need for a hab check at least whilst still in the warranty period.
That’s worth knowing, we’re thinking of going either Rapido or Burstner next if funds allow , thanks for the heads upYou only get that problem with Brit vans, German vans don't require a hab check to keep the warranty, rip of britain again.
But remember Rapido is French, not German ......................... Best to check whether or not they demand Hab checks to maintain the Warranty.That’s worth knowing, we’re thinking of going either Rapido or Burstner next if funds allow , thanks for the heads up
Just to clarify the above, if the German produced MH is bought in the UK via a dealer (or was first sold by a UK dealer) it will normally STILL need a hab check to comply with the warranty, this is usually the case with any MHs actually sold in the UK via a dealership regardless of what the terms are for their country of manufacture.But remember Rapido is French, not German ......................... Best to check whether or not they demand Hab checks to maintain the Warranty.
correct Dethleffs dealers will not just do a water ingress test they insist on a habitation check which I agree is a total rip off...Just to clarify the above, if the German produced MH is bought in the UK via a dealer (or was first sold by a UK dealer) it will normally STILL need a hab check to comply with the warranty, this is usually the case with any MHs actually sold in the UK via a dealership regardless of what the terms are for their country of manufacture.
Not correct Mel. My UK dealer, Becks, confirmed to me that my new Hymer did not require a hab check to maintain its warranty. I have never had one and yet got warranty work done OK. Hymer only require a damp check, and that is only to maintain their separate water penetration warranty.Just to clarify the above, if the German produced MH is bought in the UK via a dealer (or was first sold by a UK dealer) it will normally STILL need a hab check to comply with the warranty, this is usually the case with any MHs actually sold in the UK via a dealership regardless of what the terms are for their country of manufacture.
Hymer & Carthago certainly don't need a hab check only a damp check.Just to clarify the above, if the German produced MH is bought in the UK via a dealer (or was first sold by a UK dealer) it will normally STILL need a hab check to comply with the warranty, this is usually the case with any MHs actually sold in the UK via a dealership regardless of what the terms are for their country of manufacture.
Have you checked directly with Dethleffs or are you just going on what your dealer told you?correct Dethleffs dealers will not just do a water ingress test they insist on a habitation check which I agree is a total rip off...
I did say 'normally' not 'mandatory' ... when enquiring about MHs/campers etc from overseas manufacturers I have always been told that a yearly hab check is required to maintain the warranty, and other owners have too.Not correct Mel. My UK dealer, Becks, confirmed to me that my new Hymer did not require a hab check to maintain its warranty. I have never had one and yet got warranty work done OK. Hymer only require a damp check, and that is only to maintain their separate water penetration warranty.
Of course some less scrupulous dealers may tell their client otherwise, but they are not telling the truth.
Can you please tell me where to find this information direct from the horses mouth (not that I don't believe you, as a I do), so that when we get to year 2 of our MH ownership I won't have to pay £400!Hymer & Carthago certainly don't need a hab check only a damp check.
Do be aware British dealers will tell you they need a hab check when in fact they don't.
I have tried several dealers and all only do the full monty at a special price for the owners club of £250. The chap that runs the club thinks he has done everyone a great service negotiating such a great deal for us members. In the handbook it does have a list of items to be covered in the habitation service in addition to the water ingress check but no more than you should get anywhere. Seems to be a closed shop.Have you checked directly with Dethleffs or are you just going on what your dealer told you?
My best mate has had 2 Cathagos a C-Tourer and currently an E-Line he hasn't had a hab check and had warranty work done. Current one brought from Go European they confirmed it wasn't necessary.Can you please tell me where to find this information direct from the horses mouth (not that I don't believe you, as a I do), so that when we get to year 2 of our MH ownership I won't have to pay £400!
