Hab Door (1 Viewer)
Jul 6, 2016
1,547
1,264
West Sussex
Carthago Chic A clas
Since 1990
I changed the complete lock on a Hartal hab door. What make of hab door do you have ?
BILL 875
Sep 18, 2015
699
703
Selby, North Yorkshire
Rapido 8066DF
to add it only operates from the inside, the dealer took the inside panel of and took a picture prior to getting a new one.
Bill
canopus
6,145
10,285
rural Lincolnshire
Carado CV640 Pro
Does it need collecting from Brownhills Bill? They are only a few miles from us I could pick it up as Im passing tomoz if you like.
Oct 20, 2010
2,251
37,619
Burry Port South Wales
Since 2003
Is it like this
BILL 875
Sep 18, 2015
699
703
Rapido 8066DF
Hi It is very similar to your door, mine has the waste bin mounted on the door there are 2 screws on the opening handle, then the panel must come off, do you think it is clipped on or velcro or something similar.
Bill
Oct 20, 2010
2,251
37,619
Since 2003
Mine has industrial velcro.
With mine I remove the 2 screws holding the grab handle, one screw on the door handle gear. Part remove the rubber door seal on the panel.
I use a small spatula or filler knife to prize apart the velcro sections, I think there are 4 sections. It's a bit of a fiddle getting the door handle mechanism through the panel.
5 times I've removed the panel on ours to change latch springs and the central locking solenoid.
Have fun.
Cheers
Ed
BILL 875
Sep 18, 2015
699
703
Rapido 8066DF
Hi Sheddy,
I got the handle off easily, but the panel itself is fixed on by the old style plastic push in buttons similar to the ones some cars have on the interior door panels line them up and bang em in, at least i can get panel on and off will get new lock tomorrow. Thanks again for your help, Cheers
Bill
BILL 875
Sep 18, 2015
699
703
Rapido 8066DF
Hi, I did have a quick look at the old lock at the dealers but cant remember the details i will collect the new one today and will see then but it does look to be similar and like you say can be fixed.
Bill
BILL 875
Sep 18, 2015
699
703
Rapido 8066DF
Collected new door lock on the way to the old bush blues festival and was as the one in the above picture, total time to fit it 40 minutes give or take, needed a third hand to fit door panel supplied by funster Graham works a treat now, it should do it cost £71.
Thank to all for the advice.
Bill
Feb 22, 2016
3,639
10,977
York
Bailey 620 Approach
Have fun.
Cheers
Ed
This is exactly what we have done and sorted a faulty solenoid operating the door lock. Getting the door stripped down was relatively easy, as described by Sheddy above.
We replaced the wiring to to solenoid and reassembled. Needed to drill a small hole to feed the new cable thought to connect up.
At the price quoted for a new door, I’d certainly investigate a repair yourself first. Good luck. I posted on this some time ago. If you want, I can find the photos I posted of the repair.
Edit: I note right after I posted, that you have the matter sorted. So ignore my post.🙂👍👏
