Gordon Bennett (2 Viewers)
Jun 2, 2023
51
29
Lancashire, UK
Benimar 143
I'm a newbie (ISH) 2022( type 2 VW's and caravans 1980 s to 2022)s
Gordon Bennett it's done it again. This time the hob hot plate tripped it. The microwave and hot plate appear to be on the same circuit. Marquis told me that the microwave is no longer under warranty but it is clearly not simply the microwave that causes the problem as a result of the hot plate trip. The RCD will not immediately reset. I managed to reset it the last time it tripped but it would not reset immediately. If it was an appliance issue I would expect the the RCD to reset straight away provided the relevant appliances are switched off.
I am inclined to think it is a motorhome wiring fault causing this intermittent trip. But I'm no expert. Marquis said they could do a £120 diagnostic but I don't trust them.
Any comments would be appreciated.
The Coops
2,160
39,511
The Fylde
Adria Compact DL
Yes, thank you
Whereabouts are you in Lancs.? If anywhere near Kirkham try Sparks and Sensors ( Brian) a very good auto electrician that is au fait with motorhomes
Chainwheel2
Jun 2, 2023
51
29
Lancashire, UK
Benimar 143
We live in Penwortham but store MH in Freckleton so would be a good one to try . Thank you. When we get back. Sat in the clouds rain and wind in Dumfries and Galloway at the moment.... still it's beautiful .
43,767
52,847
As the RCD won't immediately reset it could be a faulty RCD.
Do you have the knowledge and ability to swap for a different one temporarily.
If the same circuit trips it proves the RCD is ok.
If the swapped circuit trips it's an RCD fault.
Chainwheel2
Jun 2, 2023
51
29
Lancashire, UK
Benimar 143
Agreed. I will try and get it checked out. Thanks.
lorger
9,944
92,505
Dumfries
Knaus Sun 650MEG
It’s certainly been worse than normal weather we’ve been having lately, tomorrow is meant to be nicer.
Chainwheel2
Jun 2, 2023
51
29
Lancashire, UK
Benimar 143
We like it around here people are nice and friendly slowing down and waving when passing us while we are walking the dogs
MisterB
6,715
15,465
Essex
Adria 670 SLT
We have a surge protector, it doesn't reset immediately, if we leave it long enough then it resets itself but I always reset it manually anyway.... Could yours be the same issue ?
Which reminds me that I need to move the surge protector to an easily accessible location .....
Chainwheel2
Jun 2, 2023
51
29
Lancashire, UK
Benimar 143
It won't reset up to now .so going to have a wee dram...cheers
Chainwheel2
Jun 2, 2023
51
29
Lancashire, UK
Benimar 143
Hum the two offenders are built-in so a bit of a pain
Chainwheel2
Jun 2, 2023
51
29
Lancashire, UK
Benimar 143
We haven't given up but up to now can't find anywhere to get the microwave out .we are moving on tomorrow so will keep looking in daylight.
Chainwheel2
Jun 2, 2023
51
29
Lancashire, UK
Benimar 143
Had a word with sparks and sensors and he explained they don't deal with 240v systems. But he suspected that it is a faulty RCD or wiring fault in the motorhome. Not the microwave or the hotplate because you wouldn't expect them both to go down at the same time especially as neither are old and have had much use.
