Leakylunar
Hi our VW T5 is struggling to start once it starts it’s very lumpy. Once we set off it revs freely with good acceleration, only once at tickover does it become lumpy again. Any ideas other than glue plugs?
I wonder if by using diesel redex I’ve caused the problem but I’ve always used it
Then it definitely isn’t glow plugs or their relay.Even when upto temp at idle/low revs it’s lumpy
Good news in reality. It’s much easier to sort a current problem, than search for inconsistent one.Well quick update, set off to garage and it started 1st time no lumpyness
After 5 miles van just stopped!
Managed to pull after several attempts it started, it then stopped again on Castle street Hull( very busy) again after an age it started eventually getting it to the garage.
He’ll look at it on Monday![]()
Why don't they test the injectors rather than firing the parts cannon?A quick update, tried fuel pump,low and high pressure pumps still having problems they rang Friday to say next will be injectors !!!!!!
This will be costly but really have no choice, fingers crossed this works.
