- Jun 20, 2022
- 342
- 380
- Just looking
Thought I'd start new post as, been a while since the first one about the fault, and this will be a long explanation.
Fiat Ducato 2.3. 36K miles.
Starting OK from cold, no faults.
Next start when warm, glow plug light flashing and message on dash saying " check glow plug "
Decided to do a resistance check.
Took passenger side headlight out, can see Bosch glow plug relay directly below but still awkward to get to.
Jacked up, removed wheel then wheel arch liner.
Now easy to get at from below. Removed the one holding nut.
Was able to wangle the relay up to a nice position.
Removed relay from the wiring connector.
Checked resistance of each plug in turn at the connector, with a fluke.
Approx 1 Ohm on 3 of them but 250 Kohms at the 4th one.
Double and triple checked.
This means either the plug is duff or a wiring fault.
My bet is on the former but will defo check the wiring.
However. They are badly shrouded by all sorts and the only way to get at the plugs and the connectors is quite a bit of dismantling.
Have had a good look at prutube and all the vids so far show how to remove glow plugs BUT none show the work leading up to the point where you can get to them !!!!!!
I find this to be very common on crumbtube.
SO, have any of you seem a decent vid showing ALL the work?
Incidentally, while doing my self build I did watch quite a number of build series and a common theme is for people to do some "unboxing" (wow) and next thing you know the item is fitted but not shown how it was done!!!!
Wish I had the time, money and video kit do do another build.
Happy Jack.
Happy Jack.
