Our 2012 Bailey came with a Gemini alarm fitted. Probably the most non-friendly user manual ever!
Anyway, the hab door has a magnet fitted which operates a reed switch which should operate the alarm, if set, when the hab door opens. We disable the internal sensor when sleeping in the van but my understanding is that the alarm should still operate if the hab door is opened. It doesn’t. The bonnet switch operates correctly as does the internal sensor.
What can I try/do to get this to work? There are small red leds on the door sensors that operate when close together and I’ve replaced the batteries.
Thanks in advance.
Thanks in advance.
