On the Mopeka pro you can set default update to 30 seconds so should last a whileI change the update rate from the default 3 seconds to the 10.5 second option in the app, and I get 18 months to 2 years of battery life.
what size batteries are required?I have had them on both cylinders for about 18 months. More than happy with them. Seem accurate. Batteries need replacing every 7-8 months.
AAAwhat size batteries are required?
I have had a Mopeka for at least a couple of years, but am unable to securely fix it to my Gasit underslung tank. I've tried a number of methods but no success. Someone suggested an aluminium sling over the top, under the sensor and across a cross member, which is beyond me. Any other ideas?My Mopeka is on our underslung tank and accurate.
Between the circular (pro) one and the other (rectangular) one discussed here, which is the better option in use please?
They are both on Amazon. I am just nit sure which one to buy.Watching with interest. I’m looking at the Mopeka Pro <Broken link removed> that comes with a mounting collar. Can’t readily see a U.K. stockist but Carbonzorro in Poland have them so I’ll try their LPG Shop affiliate over here if not direct from the States.
CR2032what batteries do they use out of intrest
