Gaslow or Gasit ? (1 Viewer)
Russ M
117
76
South Devon
C Class Dethleffs
Since 2013
We have a fully winterised van with Alde heating.
We want to take it on ski holidays , and looking at other threads on this forum , two 6kg calor bottles are not going to cut it.
Think I will fit LPG bottles. Ideally 2 x 11kg if they will fit in my locker.
Gaslow seem to be very popular but also very expensive to buy and have fitted. I’ve also seen a company called GASIT in North Wales which are much cheaper ( almost half ) than Gaslow.
Anyone got any experience of GASIT at all ?
And also , any tips on running with LPG much appreciated.
Thanks in advance.
Lenny HB
53,476
150,198
On the coast in West Sussex
Hymer B678 DL
Gaslow & Gasit cylinders are made in the same factory in Poland. Gasit off 4 hole & 2 hole bottles, the 2 hole bottle are a fair bit cheaper but you need the 4 bottle if you want an accurate level guage.
mikebeaches
5,395
8,603
Bristol
Rapido V68 Van Conversion
Since 2009
I've got a gas-it refillable 11kg cylinder, plus a 6kg Calorlite as a backup. But we don't go skiing.
Very happy with gas-it though.
Refillable LPG bottle(s) is definitely the way to go for continental travel.
Badknee
7,408
412,945
notloB
Vantage Neo
Living the dream.
Gasit for us, 44ltr underslung tank. Good company to talk too as well.
Vic
Aug 1, 2010
461
536
If you like yellow, buy Gaslow. If you like red, buy Gasit and save money.
Ideally, as previously mentioned, under tank is probably the way to. I wish I had.
Jul 5, 2013
11,731
13,709
Since 2013
As others have said there is not much difference between them. Gaslow seem to be marketed through caravan and motorhome dealers whereas Gasit sell direct and through LPG experts.
I fitted Gasit myself in both of our motorhomes and have had no problems with it.
Sep 17, 2017
5,467
10,214
Birmingham, UK
A-Class
We went for an underslung tank for our van. Main reason was to save space as we're only 5.4m and the gas locker has been repurposed for other storage. Other bonuses are we can carry a bit more, and the weight is now low and between the axles, rather than behind the rear wheels and upright. Disadvantage is that it's expensive and, when going on the ferry/tunnel I have to crawl under the van to switch off the regulator.
Regardless as to whether you get an underslung tank or just switch to refillable bottles, I'd recommend getting an external fill point. Lots of garages don't like people filling bottles, but they are perfectly happy for you to fill up through an external nozzle.
Mar 23, 2012
9,551
32,134
sleights
c class
We have an in the locker fill point and have never had a problem
tuscancouple
552
964
Kent
None
There’s also Alugas for the payload conscious.
We've just had two 11kg bottles fitted in our PVC by Autogas 2000. Could only fit a 25kg underslung tank and as internal space isn't really an issue, decided on the simpler option of replacing like for like. Saved a little weight as well.
Mick
Dec 30, 2017
141
163
North Devon
Be careful when comparing prices for Gaslow and Gasit.
The standard Gasit bottles are a little cheaper than the Gaslow ones but they are not the same specification.
The Gaslow bottles are a higher spec. and cheaper than the equivalent Gasit Plus bottles.
Jim lea
107
226
Surrey
Since 2014
I can’t see that, they are just metal storage containers at the end of the day
Zigisla
2,580
3,106
Gosport, Hants
Sunlight A72
Getting better month by month.
That have the ability to shut off automatically when you have reached 80% storage and can give a reasonably accurate contents reading and will stop the flow of lpg in the event of a ruptured hose on the hp or lp side for safety. ;);):D2
Or not. :LOL::ROFLMAO:
Nov 21, 2017
23
9
Kent
Having been let down by a local fitter, I am considering self installing a Gasit system. However, my insurance company apparently require it to be done “professionally”. Since Gasit themselves advise notifying one’s insurance, has anyone found a way to diy compliantly?
Peter
Nov 17, 2012
1,930
2,614
WEST SUSSEX
HYMER B SL 674
SINCE 2005
I installed mine but I had a normal gas check carried by my local dealer that ticked off all the appliances including the Gaslit installation. You also get a certificate of compliance.
Familymad
104
56
Dethleffs XXLA
2yrs
Took my time researching all the different refillable LPG options for our MH. I originally wanted Alu Gas but just couldn’t justify the price difference for a couple of KG saving in weight. I have a habit of changing things every 2-3yrs and figured I wanted a removable filling set up (in locker fill kit) so I could re fit to another MH. This would also mean I didn’t drill a big hole into the MH side for the lpg filling point and would allow me to DIY fit. So I was down to Gasit or Gaslow. Red or Yellow!
We wanted twin 11kg bottle with auto changeover and all tails and pipework. The price difference between the two kits was £200 and after much research, the final selling point was super quick and efficient customer service answering my dumb questions on the kit and how to fit it from Gasit. They got my cash.
Fitting took 2hrs after dry fitting in our kitchen first. The hardest bit was filling the system with a couple of litres at the local Asda @ 59p per litre. In short, read the instructions on the LPG pump and don’t just try to do what you think it requires...! I filled with 2 litres and pulled away to the car park for leak checks. Had three little areas and nipped them up. Came back and filled to full (or actually 80% limited by design) and it’s been awesome.
