Gasit or Gaslow advice required
Cookiedoodle
Sheffield
Newbie since May 2014
Morning all
I ran out of gas at the weekend. Not a big deal as we weren't staying far from home but I'm looking to get a refillable system. Are they easy to install. I have a Rollerteam Autoroller 700 on an 07 plate if that helps anyone and I have a red Calor tank in there at the moment.
I only need 1 x 11kg bottle but is it also possible to have a feed for a portable gas barbeque (thinking about a Cadac Safari but that a whole other conversation!!). I don't want to have a permanent bbq external point just something I can feed from the locker (is this even possible?). I have done lots of research and searching on the forum but want to be able to install this myself. How easy is it to do? Is the Gasit better as it has an external filling point. I am going to spend a couple of weeks in Europe and wanted to draw on the wealth of experience out there.
Thanks in advance guys.:thumb:
As an ex gas fitter i am amazed at the number of gas 'experts' there are. :Eeek:
Agree with you but the gasit setup is really no more than changing a normal gas bottle , you don't have to get an expert out for that
Did all my gas pipes at home when I installed the kitchen except the gas hob which I had "expertly" fitted. When I returned home from work I could smell gas, Guess where the leak was comming from? I'll give you a clue, it wasn't my work ! Gas safe :Eeek:
Just installed gasit to my motorhome and it was very straight forward with in locker fill point. Tapped into gas pipe beneath vehicle and installed bbq point, gasit even provided free leak detection spray:Smile:
Lee.
I've had two gas leaks in my house, both down to work by "professionals". I've done a fair bit myself but always leak test assiduously with my own manometer. Why? Because I live in my house and am not in a hurry to b*gger off to my next paying job.
Don't diss the DIYer! Of course not everyone knows what to do but we've got a much stronger incentive to "get it right" than many professionals.
Tim
Gas it - Gaslow
The only concern you may have is if anything goes wrong how do you prove the installers (your) Gas fitting competency. caravan and motorhome engineers are or should be trained on LPG for a reason.
I was about to install a Gasit 6kg with external fill point but hit a snag. The whole locker is lined with galvanised sheet metal.
Any ideas ?
Should have a gas drop vent if not it needs one. Just cut a hole in the floor with a hole cutter to take the filler pipe through.
