I had two Truma regulators fail. The second one was bought by me and was less than 6 months old when it failed. Fitted a different make and since then, no problem. Now carry a spare regulator just in case.I have lost count of the number of failed regulators I have chucked in the scrap bin. Certain makes are really bad for being affected by oily deposits. Other, usually cheaper makes rarely fail
This is what we fitted second time.
Cavagna Low Pressure Regulator 30mbr (10mm)
1.5kg.hr flow rate with pressure test point Comes with fixing plate and compression stepped olive fitting for gas pipe fitting. For use in gas locker. M20 inlet accepts W20 threaded hose connections as used on pigtails etc.
