Gas Locker Floor - Luck Was With Us! (38 Viewers)
Jul 14, 2022
649
1,301
Autosleeper Dorest E
Jul 22
Hi all
Thought I'd share our experience as not sure if this is a known thing or just an unfortunate event (hoping it's the latter!)
Whilst (luckily) driving through the grounds of Chatsworth (private stately home) doing no more than 5mph, we heard the biggest thud and a sound of dragging.
Whilst trying to look for a safe place to pull in, an oncoming car flagged us to stop.
Our spare gas had fallen out of our locker, onto the oncoming traffic due to our gas locker floor failing completely, with the connected gas hanging on by the pug tail, scraping the floor!
We have a 2008 Elddis Autoquest 140, bought in Jul 2022, where luckily our dealer has said he will stand to the repair.
Have read this to happen to caravans but not so on MH's.
Just makes you aware of how flimsy the floors can be, and just grateful it didn't happen on a main road or a motorway and it didn't hurt anyone or their vehicles.
Both were secured but gravity won the battle and the spare went rogue!
Photos attached (floor completely gone and what the floor looks like)
Elsie2010
Jul 14, 2022
649
1,301
Jul 22
Bloody hell. You were lucky then.
Imagine that at 70 on a motorway 😮😮😮😮😮😮😮
So very much so!
Stupid old me then decided to forget to bloomin lock the gas locker after we had sorted the incident (despite hubby telling me to 3 times) and that then flung open on a main road on the way back (my head was foggy from the gas incident, no excuse I know)
The other lucky thing was, hubby forgot to turn gas off from our last outing so the one that remained in the locker (albeit on no floor as that had totally gone) was 'live'
Lucky stars yesterday and lessons well learned on checking gas is off on every journey, regardless of it not being used since the last
Elsie2010
Jul 14, 2022
649
1,301
Jul 22
Wow...lucky as you say.
Was this not picked up on in any hab check ?
Unfortunately not, although last hab check was Jul 22 so not sure if it was ok then, and not so now?
When it goes it for floor to be repaired, we're bring hab check / service / mot forward and getting it all done then.
If they say what caused it, I'll repost in here in case it's of any use to anyone
Minxy
33,561
69,798
E Yorks
Carthago Compactline
I suspect the fixings have gone rusty and with the weight of the bottles bumping around in the locker it just couldn't stay in place.
401
1,472
Essex, UK
Since 2014
I noticed a similar problem when I changed the 2x leisure batteries.
Not total collapse but well on the way.
In my case, the cabinet floor was secured by aluminium rivets which had been attacked by road salt to the point of disintegration
The cabinet walls and floor panel were galvanised so all ok, just the rivets gave out
Elsie2010
Jul 14, 2022
649
1,301
Jul 22
It's just not something you'd usually consider to be an issue (or is that just me being a newbie to the MH world?) Glad you noticed yours, its a scary ordeal (not just for us but the unlucky road uses the gas hurtles towards)
401
1,472
Essex, UK
Since 2014
Sometimes parts of our MH’s are a bit cheap and cheerful
16
25
New Forest, United Kingdom
Rapido 691
Newbie
Found this when I checked the gas hoses and regulator dates ( both now due for replacing) stripped down as much as possible either side of rain showers so now organising wood and delam stuff to repair. Now also have eye strain and a headache from you tube vids and going on our next jaunt for 3 months at the end of May, no pressure then!
818FEE9D-9B71-400F-8157-83D4CA3EFF7A.jpeg A2C15C6A-BDE6-4B57-80AF-4597110E5548.jpeg
Elsie2010
Jul 14, 2022
649
1,301
Jul 22
View attachment 736847 View attachment 736848
Oh blimey! Good job you were checking the hoses etc, it's not something you'd expect (or maybe that's just me) Hope you get all sorted (sure you will) and you have a great and safe trip
1,748
6,561
N/E Lincs
Autosleeper Rienza
as above
I was pleasantly surprised to find the gas locker floor on our Rienza was a pierced metal plate rather than wood. Not long after we started using it I heard a rattle from the o/s. It wasn’t until I came to change the bottle that I found the floor was not secured along the outer edge.
On investigating it had been riveted with two normal size rivets that had pulled through the floor plate. I re-secured it with four flanged larger rivets and large washers.
From what others have said we got away with this lightly but the thought of the two 6kg bottles dragging on the road is scary😦.
Elsie2010
Jul 14, 2022
649
1,301
Jul 22
Oh crikes! Although, in my head you'd think met would be more resilient than wood?
Glad you located your issue and all was safe and well
We hope this post and replies such as yours and others, helps to bring attention to something we all assume would be safe and fine
2,120
2,678
Our 2012 Elddis Aspire 255 was subject to a notification to have the gas locker floor rebuilt.
13,506
102,960
Bolsover, Derbyshire
Hymer S800
not long enough
Very scary story, glad it worked out OK, I am surprised that your bottles were not also held in by securing straps to the wall, not just dependent on the floor 🤔👍
Lenny HB
56,221
165,175
On the coast in West Sussex
Been there done that but it was my own fault.
Our first Hymer the gas locker was very low base would ground on speed bumps if not careful.
New van only has it a couple of weeks and our first trip abroad in a Motorhome partly ripped the bottom off the gas locker pulling out of a car park on the road of a 100 hairpins in Slovenia. I was on full lock pulling out of the car park on a 1 in 6 with a big lip up to the road.
Strapped it up with camlock straps & gaffa tape. When we got home a few weeks later undid the straps & tape and the bottom just fell out with the bottles.
It was all GRP so an easy repair I cut two inches off the sides and back rebonded the floor with GRP and added some aluminium strips for extra support. Result no more ground clearance problems as the base of the locker was two inches higher.
1,748
6,561
N/E Lincs
Autosleeper Rienza
as above
The two bottles in ours are held by two tension lock web straps as as a lot of others probably are but they will only hold bottles from sideways movement. Something as smooth as a gas bottle will just slide down.
I helped un load welding bottles from the back of a Bedford truck when I was in the army. They are hard to grip upright making it difficult to stop them sliding down on to my feet. I made sure I was the one at the top next time.
Elsie2010
Jul 14, 2022
649
1,301
Jul 22
They were on really tight, or so we thought. I can't even open a jar of jam after hubs has had his paws round it. Must be the heavy weight of the bottle out-did the straps once the floor gave way?
PP Bear
8,311
31,546
Kent, UK
Auto Trail Dakota SE
Wow, I’m so pleased that it happened at low speed and gutted for you I’m picturing sparks as the bottle scrapped along the road, which ain’t good when it comes to gas cylinders.
Hope it’s not too much hassle to fix.
TheBig1
Nov 27, 2011
17,851
44,362
Far more common than it should be, especially with 2 13kg bottles. The last one I repaired, I made a new floor from aluminium chequer plate and angle. If I was doing another, I would measure and have an aluminium tray made with tall enough sides and back to screw to the inner walls. I would have it welded together so it would be super strong and have drop out vents drilled in the floor. Some vans now ship with plastic locker floors, which can crack but don't rot away
8,018
27,421
Cheshire
C Class Elddis 175
8+ years
Hi all
View attachment 736769 View attachment 736770
Wow, thanks for the heads up. Glad everything was OK and no real harm done apart from a scarey experience.Will be checking my gas locker tomorrow. (y)
As said the floor looks OK and it just fell through due to failed fastenings.
