Gas Locker Access (1 Viewer)
Oct 29, 2019
410
1,358
VW LWB Crafter
I sure I've read somewhere that legally you should not be able to access the locker from inside the van?
Can anyone shed any light on this, my build did initially have access only from outside but a change of plan may well put the bottle in a locker below the cooker.
<M>
Mar 30, 2019
1,089
1,380
East Sussex
Trigano Tribute
Since 2017
I can access mine from inside if I open the back door and lean to the left at a stupid angle!
Mines actually under the wardrobe floor, it’s not that obvious if the timber is sealed in anyway but it does have 3 down vents to the outside.
Sep 29, 2019
289
519
Forte
10years
Would love to kow this as well. Very tempted to put an access hole inside to be able to turn the gas on after arriving at location
Mark and Mindy
1,033
4,828
Nr Bicester
Adria Twin 640 SGX
Since 2019
In our PVC the gas locker was originally under the bed and the gas locker door was accessible only by opening the back doors of the van. We had our gas storage converted to an underslung tank so the gas bottles and all the gas regulator paraphernalia was removed from the gas locker. To get extra storage space I dismantled the gas locker and in doing so I realised that the compartment have been completely hermetically sealed from the rest of the van with silicone in all the wood joints and rubber strips on the doors and of course there was a vent to the outside in the bottom of the locker.
Mark
Basildog
2,217
3,625
Up to 2 cylinders in an internal locker with a maximum capacity of 16kg each .
Sealed door /hatch the bottom of which is not less than 50 mm above the compartment floor
Drop out vents dependant on cylinder size but normally minimum 2% compartment floor area not less than 10,000mm2
Next Stop
Oct 29, 2019
410
1,358
VW LWB Crafter
By the look of your avatar I can take this info as gospel?
So if I were to install 2 vented has lockers internally each of which could hold a maximum of a 7kg bottle this would be ok?
Basildog
2,217
3,625
No lol
Do your own research it is all information you can find but it will vary depending on how you decide to do your installation.
Yes you can certainly have your internal locker đź‘Ť
32,725
66,819
No reason why you can't have it internally so long as it is fully sealed (including the door) and meets all the safety requirements - I did this back in 1996/7 when I converted an ambulance and the gas locker was inside below a full height wardrobe/cupboard I installed.
Also when we had our last Globecar as the gas locker was in the rear under the bed in order to turn the gas on/off I had to open the rear doors and then remove all the stuff at the side of the locker in order to get into the door which opened under the bed (stupid idea!) consequently I installed a hatch on the end wall of the locker so I just had to open the rear doors, take the hatch cover off and stick my arm through to do it.
2,499
10,924
Thanks for this idea..
I want access to the gas locker to isolate the bottles without removing a tow ball bike rack with two e-bikes. ..
I saw this hatch on Gaslow and now seeing it here has confirmed it's a good plan,
cheers
