- Aug 18, 2014
- 26,726
- 163,901
- Transit PVC
- 16 years since restarting
On the attached photos I am blowing the 20A fuse,marked B, when the ignition is switched on?
Originally it was wired direct to the starter battery & not through the normally closed switched relay. When it occurred the first time I thought that fitting that would remove any back feed? If the fuse B is uprated then fuse A blows ?
If the HL link on the Orion is removed then it does not happen?
Anyone any ideas?
Or do I just need a completely seperate solar supply to the starter battery?
I
Anyone any ideas?
I
