- Dec 23, 2015
- 445
- 524
- Pilote Pacific P650GJ
- Over 6000 miles between 3 March to 26 September 2017.
Can I still be classed as a beginner after nearly 8 weeks? I'm panicking like mad as we had a frost here last night, this morning the car was frozen over. We haven't drained the motorhome down. I presume the heater will have dumped its water, but do you think a mild-ish frost will have harmed the pipes/taps? You really shouldn't have to think about frost at the end of April in the middle of England (well just above middle).
I'm at a loss to know what to do regarding water. If I don't put much in we keep running out, last time I filled it showed 75% and that takes some getting rid of, other than running it all through the taps and then having to keep emptying the grey waste. And then, where can you empty a full grey tank if you're not on a site with a drive over point. Our grey waste pipe is almost an arms length under the motorhome and I have to lie down to stick a bucket under it and then struggle to get it out. I have fitted a "pond pipe" extension but it will not empty into a bucket because the end of the pipe is then higher than the waste pipe on the tank. What does everyone else do?
