Fridge not cooling (1 Viewer)
MaryR
3
Fiat ducato van
We’ve just bought a second hand IH Fiat Ducato, the fridge Dometic RM8401 is not cooling or freezing at all. Fridge light on and panel lights seem to work with no warning flash’s. Lady owners so totally lost where to start! Would really appreciate your thoughts on this please.
tried on Gas and this seems to cool slightly but nowhere near cold enough to make ice.
Jan 8, 2013
8,493
11,530
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
There's a gas jet at the bottom of the fridge at y back. It's easily blocked..Take of the bottom cover and you should see the gas flame
Reactions: f6c
M
MaryR
3
Fiat ducato van
Thanks will check this, is this the panel on the outside of the van behind fridge?
This wouldn’t solve it not working on Electric would it?
Oct 10, 2018
2,013
1,140
Bracklesham Bay, West Sussex
PVC
Are you aware that the fridge will only work on 12volt setting when the engine is running also have you set the temp level display to a high setting for it to work as it should on gas or 230 volt.
Eggs
1,633
2,934
Suffolk
Are you aware that the fridge will only work on 12volt setting when the engine is running also have you set the temp level display to high for it to work as it should on gas or 230 volt.
I don't understand the last part of this statement, can you explain it please.
Jan 19, 2014
9,396
24,794
Derbyshire
Elddis Accordo 105
since 2014
Is there heat coming up out of the top vent outside? If you take the top louvres off the fins should be hot on the right and cooler on the left.
Another check you can do is remove the aluminium fins inside the fridge and freezer, (they are just held on with screws) and see if the pipes behind will frost up, or how much they frost up.
John H.
181
104
Hymer 578
A long time
I would not expect the 'freezer' in a motorhome to make ice quickly, especially if your temperatures today are hot like ours.
It will probably work best on 240 volt if you plug in the hook up lead in the house. (You will need an adapter)
If not, set it to gas.
Either way, make sure that the side of the van with the fridge is not in sunshine. And put ice in and check if it melts.
Oct 10, 2018
2,013
1,140
PVC
The temp level display, on the front of the fridge , which is altered with the temp selection button being pressed sets the cooling level from not very cold to very cold, like turning a thermostat up or down (Dometic RM8401)
Eggs
1,633
2,934
Suffolk
I understand that, but why does it need to be set to high for it to work properly on gas or 230v.
Jul 24, 2015
374
947
Ramsgate Kent
Fiat ducato c class
5 years
It will need to be either plugged in to main hook up overnight for it to get nice and cold or a good few hours to use it .
On gas it should start clicking once selected and you can hear this outside near the white vent ..after clicking the gas should spark up and you can possibly hear the flame roaring .
.like ours..
Gas mode will take a few hours to be useable also .
Ice is possible if you've had it on for long time..we plug our fridge in 240 mains at least 48hrs before take off ...
Sep 11, 2018
322
366
N Wales nr Chester
Citroen Relay pvc
16yrs
Make sure the van (therefore the fridge) is level, these fridges are notorious for not working properly if more than 4 or 5degrees from level
