JockandRita
- Aug 2, 2007
- 12,688
- 174,631
- N+B Flair 8000i
- Since May 05 (Ex Tuggers).
Although no gas coming through, is the igniter still clicking, ie, providing a spark?Hi there.. just came back from a walk with the dogs, left fridge on (gas) to cool and came back to red flashing light! Checked gas (hob working) and plenty left. Tried to re-start the fridge and nothing.. no gas coming through? Any ideas on what would of stopped it working and why the gas is no longer coming through?
The next step depends upon how much you respect gas as a dangerous substance, and how confident you feel about investigating further, ie, gas off, 12v (pull the fuse) and 240v (pull the plug) isolation first, before removal of the burner, igniter, and gas jet for inspection and cleaning.
Again a green corrosion can build up on the gas jet which can be cleaned off, then back blow through with an air line. Check by looking through the jet and up to the light. Some have a fine mesh over them, so don't go poking or prodding it, hence the air line suggestion. If no mesh in the jet, a fine piece of fuse wire can be used to help clean the tiny hole, but very gently so as not to increase the diameter of the hole. Whilst components are removed, that's a good time to clean the flue, otherwise all the crap drops down over the top of the burner........unless you cover it first.
Vacuum all the dust and crap, then reassemble, and check the quality of the spark at the igniter probes. If clean and healthy, replace the12v fuse, and turn on the gas supply, then try again. DISCLAIMER.....Should you choose to act upon this advice, you do so at your own risk.
BTW, your last reference to 240v just reminded me that sometimes corrosion can build up on the 2 x pin Euro plug which these units use, especially if it is inside that bottom vent, ie, exposed to the elements. If it is, remove the plug and check the pins for corrosion.
Good luck
Jock.
