Just the Job eh!My loo doesn't need any chemicals... my deposits have a pleasant Chanel N°5![]()
rob1234 It may have the extraction fan but you may want to have a proper look as Autotrail didn't install the vent pipe to the outside on some vans, mine doesn't and have known others the same. If you take the filter out and then the small fan there should be a pipe going out through the floor, if not it's just venting within the toilet compartment.so is mine classed as a sog system ,,?
That is the genuine Thetford one.
We also have one of those, noisier and runs on for ages unless you manually press the button to stop it after use, works OK though
I had exactly the same problem on my Pilote, it's easiest to remove the toilet to do.thanks you have scared me now,,think i might leave it unless some one else comes on and says its easy ,,![]()
Thanks for this very helpful I check it out in a few days...I had exactly the same problem on my Pilote, it's easiest to remove the toilet to do.
Before you actually remove the toilet take out the cassette and remove the cover and fan and draw on floor the exact position, working from outside van measure from outside wall to centre of your drawn position, should be roughly central to access door then take a line vertically down side of van and then measure on the under floor to your desired position of hole, that will tell you where you will come out underneath.
as to what is likely on the between floors, I carefully used a 32mm hole saw with the centre drill retracted so it was just proud enough to start the hole saw and then removed the drill, that way you can carefully remove a plug of floor without damage to anything that may be in the area, mine hade nothing any where near it, then simply drill from inside the lower floor which from the earlier measuring you know nothing is in the way of, all of this is easier if you remove the toilet out of way.
I used a piece of 32mm waste pipe and fashioned a mesh grid at the outlet to stop creepy crawlies getting in all held firmly in place with some Sikaflex I had left over from previous job.
We have the Thetford fan and use thetford or domestic green tabs, but I also find emptying the cassette within 24 hours even if 1/2 full helps manages any smells as well also if you are on the move everything gets stirred up so consider when you empty.What is a nice smelling chemical additive that I could use for the cassette toilet? I read on here awhile ago about a nice smelling additive but cannot find it now. Anyone recommend one?
TA Steve
Does that say 40 shot?View attachment 709059
This stuff is amazing , we have a small black tank , but use it in both black and grey tanks.
About £14 a bottle but money very spent IMOmuch cheaper than fitting a SOG
Use the same stuff, excellent. Also use a single shot in the grey tank when touring, no smell when subsequently emptyingView attachment 709059
And your hearing is going too?My loo doesn't need any chemicals... my deposits have a pleasant Chanel N°5 aroma...
JJ![]()
As well as the normal toilet fresh for vans , we buy scjohnson Duck. Fresh disk .You just press the disc and it leaves a gell stuck to the pot each time you flush you get a nice smell we also buy a air freshener Saverieign best air freshener ever used Jasmine we like but has many others all nice and staysWhat is a nice smelling chemical additive that I could use for the cassette toilet? I read on here awhile ago about a nice smelling additive but cannot find it now. Anyone recommend one?
TA Steve
I use as well toilet products.scjohnson Duck its a gell that sticks to side of pan smells really nice when flushed. You can get from most supermarkets like tessco Morrison l have just bought from wilko £2 instead of £3 .l also buy a air freshener called Sovereign best l have ever bought expensive , but l buy from a live on Facebook fb://group/198471015773594?ref=share myWhat is a nice smelling chemical additive that I could use for the cassette toilet? I read on here awhile ago about a nice smelling additive but cannot find it now. Anyone recommend one?
TA Steve
yes ours goes to no where as well. i did look to drilling out the hole. but on the Delaware it is too close to the wheel arch for comfort... so sod it i didn't bother ... but i don't know why, but i changed the carbon filter last year... Dohrob1234 That is an option as long as there is nothing in the way. I didn't have the bottle to try as you need to drill through the double floor hoping there is nothing in the way and also when you come out through the under floor your not going to hit anything vital. Was there a reason Auto-Trail didn't install the vent pipe? Who knows. Let us know how you get on.
I would recommend, we used this last year for the first time in the heat wave in south of France works really well.I use this now in my van toilet. Very nice smell of eucalyptus oil,
Natural Toilet Casette Liquid | Solbio UK
Solbio UK: Finally a green solution. 100% organic toilet casette fluid for caravans, motorhomes and boats. Solbio contains no enzymes or harsh chemicals. Safe for children and pets.www.solbio.co.uk
Mine to, but the wife is another matterMy loo doesn't need any chemicals... my deposits have a pleasant Chanel N°5 aroma...
JJ![]()
We have SOG to, no smell in MH but when you empty it OMG, especially after an indianWe have a SOG fitted it years ago, no chemicals used nor needed.
Had to replace the fan a while back, original expensive so Manic found and fitted a computing one.
(It now adds and subtracts well!)![]()
It has a carbon filter , had a door fitted one on my Autotrail with no issues ( cassette door on opposite side from awning !! ) make sure yours is too though . Had 2 , on each PVC I’ve had through the floor , no issues again opposite side from awning . Fitted them all myself, easy DIY job . Recommend them for no internal smells and no chemicals required.Havnt got much choice other than a door type without doing quite a bit of alteration . Not that good then Lenny H.B.If it helps with the pong factor on hot summer days it will be an improvement![]()
Peg for the nose thenWe have SOG to, no smell in MH but when you empty it OMG, especially after an indian![]()
