- May 16, 2021
- 1,342
- 1,917
- Autotrail
I would agree that the typical British Motorhome with a Sargent system, such as a Swift, Autotrail, Autosleeper etc, the cabling is not sufficient for optimum B2B use (I fitted 16mm2 between my 60A B2B and the Starter Battery and might change it to 25mm2 or 35mm2 at some time if I have some left over).Being a Swift your problem is the wiring will be way under size so you will be getting a volt drop across the wiring limiting the charging rate.
If you don't have a B2B you need to fit one to enable the battery to be charged correctly and to protect the alternator. Cables need to be sized relative to the cable length & max charge current.
You also need to replace the cables from the batteries to the distribution unit with at least 16 mm sq cable.
Absolutely no point in fitting Lithium if you don't upgrade the system and wiring to take advantage of it.
However I don't understand why you are suggesting replacing the cables from Battery to Distribution unit with 16mm2 cable? I am assuming by Battery you mean Leisure Battery and Distribution Unit you mean the Sargent unit? If so, the current rating going out to hab electrics and out to battery is very low (around 20A max) and the standard cabling (likely a pair of 4mm2 or maybe 6mm2) is perfectly adequate I would say for distribution purposes. Whilst I have 35mm2 cable between my Leisure Battery Bank and Multiplus to cope with the Inverter and Charger in there, I have just 6mm2 cable going to the Sargent PDU which is more than enough to supply an absolute maximum of 18A.
