Thanks for the link . In the end I decided to go for another Ultramax to match what I have because I think having the same BMS in each will work better together. It should arrive on Tuesday so ready for the Halloween Rally ( don’t forget my fridge pleaseSwifter - there you go!
Amazon product ASIN B07W8D36M2
I could just have used the bolt type terminals that came with the battery
I have just asked Becs to send it me - it might even be on my email, let me check ..I am about to order a fogstar 300 A battery the price they gave me was 999.99 minus any discount code, the question is who has or who knows the latest discount code or is it just fridays date?
BILL 875I am about to order a fogstar 300 A battery the price they gave me was 999.99 minus any discount code, the question is who has or who knows the latest discount code or is it just fridays date?
A great "tear down" video of a Fogstar battery here. Very clear information on how it works with regard to the heating and temperature protection. If you can't be fussed to watch it this guy rates it highly.
All upper case, no spaces?Thanks I have tried the codes no go im afraid i will wait for the latest code Bill
If you ring or email them tomorrow and tell them you are a member of MHF they will give you a 15% discount code.. Unfortunately cannot find the email with the code. Bought a 300ah 2 weeks ago for £850 and currently on first trip with it to test it out.I am about to order a fogstar 300 A battery the price they gave me was 999.99 minus any discount code, the question is who has or who knows the latest discount code or is it just fridays date?
Those battery terminals in your pic are rubbish they are pressed steel really not suitable when drawing high currents when running an inverter.Started my battery swap using a Fogstar 300ah battery. I replaced two 130ah
I collected the battery and it was well packaged - it came with threaded terminals so I have ordered a couple of standard posts to arrive tomorrow so I dont need to change the battery connections - I prefer the clip on/clip off types.
For a size comparison
Slightly bigger than one of the 130A batteries and lighter than them in total. I did like the handles on the new battery - really useful for lifting and manoeuvring as you can take the weight in both hands, making it so much easier.
I'm in a rubbish mood tonight, rubbish cheap & nasty zinc alloy.Swifter - there you go!
ThanksThose battery terminals in your pic are rubbish they are pressed steel really not suitable when drawing high currents when running an inverter.
Crimp new terminals on your cables and connect straight to the battery a far better solution.
They no longer give discounts as they reduced their prices it says about it on their website. Although prices only reduced by around 8%.Doesn't appear to be anywhere to insert a discount code now, have they removed the option to add one or is it just me?
Is that recent? Says use code but no where to insert it. See Lenny's reply above.
yes very recent, in fact pretty much the day before I pulled the trigger :-( I may wait on the offchance there is one that works this friday to make a final decision.Is that recent? Says use code but no where to insert it. See Lenny's reply above.
I spoke to them last week. No more discounts on leisure batteries as they’re discounted already.it didn't
Thanks, I did as you suggested plus added an isolator so that I dont have to lift the seats to isolate the leisure battery.I'm in a rubbish mood tonight, rubbish cheap & nasty zinc alloy.
Do the job properly, crimp new terminals on the cables and bolt direct to battery.
