Fogstar Drift battery PIN protection help (6 Viewers)
Jul 26, 2023
Self build
Just wondering if anyone else has set a PIN for the Bluetooth on their Fogstar Drift battery.
I contacted Fogstar and they sent these instructions to do it:
1. Open the app and go to the "About" section.
2. Click on the Fogstar Drift logo, which will bring up a pop-up section.
3. Enter your desired password.
4. Click "OK." The app should confirm that the process was successful.
5. Wait for 10 seconds before closing the app
I did that then tested to see if it worked by installing the Fogstar app on my partners phone. Using her phone I was able to connect to the battery and turn charging and discharging on and off without having to enter a PIN!
Has anyone else successfully prevented unwanted Bluetooth access their Fogstar Drift batteries?
I can imagine being on a campsite and someone being a silly sausage by switching discharge off and there being nothing I can do about it!
O
Jul 26, 2023
Self build
Ok, I managed to figure it out.
I was entering a 4 digit pin in the drift app and it appeared to accept it but clearly it didn’t and gave no indication.
So, I downloaded the JBD app and tried to set a 4 digit pin but it popped up saying a 6 digit pin is required!
I went back to the drift app and successfully set a 6 digit pin.
So, my thoughts are, the drift app should be improved to make it clear a 6 digit pin is required and the instructions provided should also make it clear!
Feb 20, 2023
241
390
South Yorkshire, UK
Carthago E line 50 D
I haven't done mine yet, so thanks for the information, sounds easy to do. I thought you had to or could put a password in?
