Fogstar Battery Rename - Tip (2 Viewers)
Jun 7, 2023
30
26
Burnley, UK
Carthago E-line
Hi,
So I recently took delivery of a Fogstar Drift battery, for the want of endless trying I could not get it to save the "rename". Tech support suggested "waiting 20-30 seconds" before exiting the app, I waited over a minute at times with the app open, but every time I closed it, then the name would refresh to the default.
In the end I tried a shorter name than the one I wanted, there was no prompt previously that my name entered was too long ! So, although not an exhaustive test, I found that "Fogstar 300" worked and "Carthago E-Line" worked, but not a conjugation.
So certainly 15 characters is acceptable !
Cheers
Mark
MarkHoughton
Jun 7, 2023
30
26
Burnley, UK
Carthago E-line
Hope the install is all going well!
Will be connecting up this weekend, have been waiting on a friend for past 2 weeks who is an electrician to cut and crimp the cables. I have them all measured up and everything fitted to a fire-board to fix into the garage. Just the daunting task of snipping the R37 that is making me nervous !
Apr 9, 2022
544
546
Cathargo
Yes it's a bit nerve racking! but any electronics guy can resolder it - at least that's what I told myself!
Apr 27, 2016
7,429
8,871
Manchester
A class Hymer
Since the 80s
Also, you may notice that 'R37' isn't actually a resistor at all, it is a simple wire link. These 'zero-ohm resistors' are used because they can be easily handled by the automated pick-and-place robots that build the circuit boards. But if you cut it out, and decide you need to replace it manually, then a simple piece of wire is fine.
Apr 9, 2022
544
546
Cathargo
Yes, I would go for a switch like used to be fitted!
suavecarve
8,397
42,716
Surrey/Hants
Dethleffs Trend A
July 09
Hi,
Cheers
Mark
Just trying to change my name.
Failed a few times.
Less than 15 characters
Do I need to do anything after "modify success" ?
56,235
165,250
Took me a while to find out how to change the name & then failed on number of characters, nearly gave up then twigged it.
Its a pain how the app picks up every Bluetooth device in the area .
suavecarve
8,397
42,716
Surrey/Hants
Dethleffs Trend A
July 09
I am invincible !
Aug 9, 2020
519
865
Wildax
~20 years
Yes, that was the stage that felt "I'm committed now".
