Good thought, its higher but with Li its got a very poor relationship with Charge level, can be quite high with very low charge levelIt could be that the BMS is giving an incorrect reading as to how full the battery is.
Have you measured the voltage across the battery terminals with a multimeter since the discharge switch has been put back on?
3.06,3.08,3.06,3.05. Can only change settings that have values already, and this changes a bit on each access. Upload is very slow,probably incomplete. Home Screen showing 16A capacity. ThanksWhat are the voltages per cell? And can you change any advance settings?
Yes, gettin replies but last indicated they were puzzled and contacting BMS makerHave you emailed Fogstar?
Taking the terminal voltage reading, you could divide the answer by 4 to find the average cell voltage and compare that with what the app says.Good thought, its higher but with Li its got a very poor relationship with Charge level, can be quite high with very low charge level
Not good enough, how long you had the battery?Yes, gettin replies but last indicated they were puzzled and contacting BMS maker
Since May. Worked apparently ok until now. Unusual thing tho was voltage at 100% charge always showed 13.3 or so.Would have expected higher if settings/BMS was set up well. I never accessed Advanced as didn’t know code until recently. Fogstar sound helpful and reasonably speedy with replies. I was not on the case yesterday so was a little behind in sending them screenshots. Updated them this pm so hopefully tomoro will tellNot good enough, how long you had the battery?
I had a problem with something I bought from Fogstar earlier this year and I found them to be excellent in resolving the problem.Since May. Worked apparently ok until now. Unusual thing tho was voltage at 100% charge always showed 13.3 or so.Would have expected higher if settings/BMS was set up well. I never accessed Advanced as didn’t know code until recently. Fogstar sound helpful and reasonably speedy with replies. I was not on the case yesterday so was a little behind in sending them screenshots. Updated them this pm so hopefully tomoro will tell
They promptly replaced it. It seems that it is a bluetooth interface problem reading advanced settings. they have checked the BMS settings directly and they are normal. Very happy with their handling of it overall.They are fast, get yours ready to go, nine was exchanged next day
Hi Raul,do you have a copy of the correct settings please, my battery is not charging correctly.I spotted few settings are wrong, as : under voltage protection set at 2.2v. That’s wrong, and potentially destroy the battery. Minimum should be set at 2.5v.
- balance starting voltage 3.3v, that will unbalance a already balanced pack. The voltage should be set 3.4v min with 3.45v better.
-cell full voltage 0.03v? What? Should be set at min 3.55v.
- charging under temp protection not set, why? It should be set at 4C.
-discharging under temp release -140C ? That should be a tad above -20C
There’s many more, those settings are well mangled up, I amazed the battery worked at all. Sooner or later would of stoped.
Contact Fogstar and ask them for a replacement, that bms looks that’s gone south, or lost it’s settings.
- I like this one
Charging over temp protection set at. -221.7C. Should not exceed 60C, a55C it’s better.
Post you settings and I can advise what settings are out. Each bms has a different order but all do the same exact thing.Hi Raul,do you have a copy of the correct settings please, my battery is not charging correctly.
Ben at Fogstar +447761510607 is a VERY helpful and knowledgeable chap. And, he’s on WhatsApp
Hi. Rodger RogerIvy at off-grid solutions does a good YouTube video explaining the battery settings it's worth a watch,but I'm sure Raul can sort you out with the info also,he knows his stuff.Hi Raul,do you have a copy of the correct settings please, my battery is not charging correctly.
If you post yours, I will follow each setting as it comes, and correct the values where needed.
