attached are the current App readout of my 280Ah Fogstar. It is behaving as a dead battery. It will not allow charge however, just flashing transient cell under voltage. It also will not allow activation of discharge, more understandably. Victron charger shows no current flow when on, its on Li setting. Ive included the factory set advanced settings (1st time Ive accessed it and not altered anything). Multimeter reading from terminals is 1.6v!!!. Dont know if that’s accurate in a shutdown battery however. Moho control unit behaves as if its an under voltage battery and electrics work on ehu.
Is it possible to reset BMS App. To allow charging.
You may notice the small POV (pack over voltage ) warning icon is on although voltage level is 10.3v!!?? Does this make sense?
Any help from a Fogstar experienced user appreciated.
Ill be in touch with Fogstar tomoro but advice before then will stop me thinkin too much. Major worry is that Factory settings were insufficient to shut down at safe level but I cant think of a 280A drain on an unused x weeks vehicle
thanks
thanks
