The fifth wheeler parked next to me at the Bash this year had some, I was most envious but, if I remember correctly, they were expensive in comparison.The Dutch motorhome next to me is using air cushions. Has anyone used these? Any opinions? Are they better and easier than the normal plastic ramp?
Thanks!
4' x 4' square used to be 19,99 about 40 years ago & connected to the exhaust would lift a vehicle to change tyres,etc.I think they’re expensive
BUT the fire service carry out a jack and pack process to stabilise the vehicle whilst any release/rescue is carried out., which sort of defeats the object of not carrying ramps, however the level of stability required depends on the activities being carried out inside the vehicle ...... and for most of us already fitted with our own personal air bags, that might not be a lot of linear 'activity' .., so inflatable levellers might be a good option - I would add though, please don't use them to raise the vehicle if you intend going underneath without doing the jack and pack process, as you should do with any hydraulic vehicle jacks.Don't forget, the fire service use air jacks to lift vehicles....even HGV trailers.
While these are smaller the lifting ability will be comparable.
In a helpful wayI've used them for a couple of years as they take up one 10th of the locker space that ramps might take. We can get around 5 inches of level out of them, though I notice they have higher lift ones now. I have read of punctures; I protect mine from sharp stones with a cut piece of exercise mat under each one. Delighted with ours, though you should note, If touring with a partner, any rhythmic exercise inside the van translates into quite a bit of rock n roll outside!
Just ordered some at Lincoln show ground. “Air lift “The Dutch motorhome next to me is using air cushions. Has anyone used these? Any opinions? Are they better and easier than the normal plastic ramp?
Thanks!
https://www.locknlevel.co.uk/ were saying a MH version of this was “imminent” at the October NEC show last year. Still no sign of being available though, and they seem quite expensiveThe Dutch motorhome next to me is using air cushions. Has anyone used these? Any opinions? Are they better and easier than the normal plastic ramp?
Thanks!
Just search eBay, for inflatable ramp. There’s some interesting ones for sale.Could all those with inflatable air bags provide links and prices please ...?
