Flash 630 welcome 2018 (1 Viewer)
Ruffles01
Chanson flash 630 we
Help needed please
I need to remove the rear offside corner of bumper I have removed two screws and light fittings but it seems to be held on bay the centre section how dose this come off if indeed it has to
Many thanks
Mar 23, 2012
9,606
32,382
sleights
c class
On our old motorhome there was a strip down the middle of the plastic panel that you took out then screws then there was mastic onto the bodywork. Luckily I haven't needed to get the bumper off the one we have now but suspect it will be masticed on as well as screwed.
For specific Chausson advice you could try the Chausson owners Facebook site.
Grummyb
714
2,205
Corby
Since about 2013
Hi ruffles welcome to the fun you might get more responses if you change your title
andy63
4,672
15,018
south shields
None
since 1990
I've had the plastic panels off on a 620..4 in total on mine ..top bottom and the two sides
As you say there are at least a couple screws which can be got at by removing little plugs.. After that I think you need to just ease it at the edges which may have been mastic down and have a look by easing off where you can.. from memory they use sticky tape to keep it close to the body..they have to be teased off gently..
Andy..
Mar 23, 2012
9,606
32,382
sleights
c class
Andy..
I think it's a mastic tape from memory if so needs the same when refitting especially under where screws are fitted.
