Each to their own. I was only tried to help here, not to question ppls choice. As a roofer with 22+ experience, and over 6 years fitting solar panels at industrial scale, I have filled many wear houses on thin roof with panels. I had a fair share of failure on self drilling tek’s done by partner installers. They could not be bothered to order the right screws.There is confusion between self tapping and self drilling screws. What you want is self tapping with washer, not self drilling like in post 19. The self tapping roofing screws, are conical shape at the tip, and the tread goes all the way to the tip around the conical tip. The self drilling are not so good for thin skin. It removes/ cuts to much material and water finds its way down the screw shaft later. Also the thin skin will only grab one tread if it’s drilled, where the self tapper will push it down and cut more treads into it.
