- Dec 31, 2010
- 3,067
- 7,457
- Frankia Platin i7900
- Since 2010
You probably need a low profile (LP) battery. Looking at K&S site you could get 2 x 120Ah LPs, which are the ones I have, and which are the same dimensions as the battery you have in there. Or you could get one 200Ah LP one which will cover most but not all of the space you have. I wanted to go for the 200Ah one but I did not have one continuous space available that was big enough.Had a measure to make sure the KS battery will fit and to help me decide what to go for, also took some pics of my system just now.
This is my battery area the battery in is borrowed until my new on arrives, it’s 34l-19h-16w and space for another the same.View attachment 642063
This is under bench directly above batteries and current solar controller is directly above in cupboard.
This is my Dometic charger under passenger seatView attachment 642066
Loads of room under the drivers seat but the ALDE heating pipes would prevent fitting anything large or heavy View attachment 642065
Think it would be easiest to stick with current location for batteries, just need to decide if it’s one high AH or two lower AH ones.
K&S do next day delivery.Thanks for all your replies and advice, I feel I have a better understanding of what I want/need going forward. I will order a battery from KS tomorrow with the hope it’s here for heading off next weekend, if not we’re away the following weekend too and then we’ll have a chat with my man regarding the installation so will probably be back a few times with more questions.
peterc10 the under seat heating does make a difference to the cab area in winter.
I know little about the Dometic charger but I think it has dip switches for changing settings. What model is it?Battery should be here tomorrow, had a read of my Dometic charger and it says it has a Lithium setting suitable for the Dometic lithium battery. Until I get the work done in a week or two should I change the settings? If so how?
It’s a MCA1225I know little about the Dometic charger but I think it has dip switches for changing settings. What model is it?
You only spotted Denise using her hairdryer and your good lady was hooked, hope it lives upto your expectations if not you can plug into oursIf your motorhome has a smart alternator it will already have a B2B. Check what size it is. As Vanbitz has worked installed the present solar, ask eddievanbitz as he will probably know.
I think you need more solar and more battery capacity. The more the better if you are planning to use it in winter in Scotland. As for the inverter the largest load will be the hairdryer. If your wife uses a small travel one you will get away with 1500W.
I recently fitted 2 x125Ah K&S lithium batteries as direct replacements to existing AGMs. I also added a B2B because my motorhome did not have one and uprated the solar controller. I already have 250W of solar, but I may add another 100W panel to give it a boost.
My good lady had been hooked many years before. My instructions were to get her a hairdryer when we first started motorhoming in 2013. That is why I bought the inverter she is still using. The only difference now is that I am using better batteries so she can use the hairdryer more oftenYou only spotted Denise using her hairdryer and your good lady was hooked, hope it lives upto your expectations if not you can plug into ours![]()
We have a small hairdryer in the van probably gets used about once every two years, we also have a gas styler that gets used about once a year.The hairdryer is on a wish list rather than a must have, we’ve been motorhoming 12 years with only occasional use, it’s when we retire and use the van more she would like option.
The charge voltages are set using the DIP switches. KS say the maximum charge voltage is 14.6V and the recommended is 14.4V so you will need the lower Dometic switch over voltage of 14.4V. KS give the float voltage as 13.2-13.3V, the nearest Dometic float appears to be 13.5V, the alternative 13.8V is too high. The DIP switch positions are given in the manual but if your manual is not to hand here is a link to the online version.It’s a MCA1225
Thanks, I had a look at that and just confused myself, is float voltage the same as retention? They also mention constant voltage.The charge voltages are set using the DIP switches. KS say the maximum charge voltage is 14.6V and the recommended is 14.4V so you will need the lower Dometic switch over voltage of 14.4V. KS give the float voltage as 13.2-13.3V, the nearest Dometic float appears to be 13.5V, the alternative 13.8V is too high. The DIP switch positions are given in the manual but if your manual is not to hand here is a link to the online version.
[/BG]
I was going by the links at #67. 3 of the 4 links give 13.2-13.3V and I hadn’t spotted the one that gives 13.3-13.6V. It would appear that one model has a wider range.Are you sure that float voltage is correct? I have exactly the same batteries as lorger and K&S give the float as 13.3v - 13.6v.
They do appear to use the term Float at one point and Retention at another. Very confusing but I think they must be the same thing. I agree it looks like Dip 1 on, Dip 2 on and Dip 3 off would be best. The Absorption phase seems to be controlled automatically by the tail current which should suit LiFePO4 well because they have a rapid drop off of Amps when they are full.Thanks, I had a look at that and just confused myself, is float voltage the same as retention? They also mention constant voltage.
I think I should have 1 and 2 on.
Gerry - where have you fitted the inverter? We've got 200ah under the driver's seat in our Campscout & a Victron B2B, under the passenger seat is the Elctrobloc & a Victron mains charger. I'm wondering about under the rear seat but that seems a tricky route for cables.I've got a victron phoenix 12/500 PSW inverter as well - that is for charging e-bikes and other small electrical items.
Helen doesn't own a hairdryer!!!![]()
I removed the plastic louvre on the rear of the driver's seat and tapped 4xM4 threaded holes in the rear of the driver's seatbase and mounted the inverter on a marine ply plate.Gerry - where have you fitted the inverter? We've got 200ah under the driver's seat in our Campscout & a Victron B2B, under the passenger seat is the Elctrobloc & a Victron mains charger. I'm wondering about under the rear seat but that seems a tricky route for cables.
ThanksI removed the plastic louvre on the rear of the driver's seat and tapped 4xM4 threaded holes in the rear of the driver's seatbase and mounted the inverter on a marine ply plate.
Easy to wire with short cable runView attachment 680325
Thanks. I have a feeling I’ll have to find a prettier solution to keep everyone happy here!I removed the plastic louvre on the rear of the driver's seat and tapped 4xM4 threaded holes in the rear of the driver's seatbase and mounted the inverter on a marine ply plate.
Its a compromise - there is not a lot of easily accessible space to site a hidden inverter in a PVC - in this location it is accessible and easy to switch on / off as necessary and you want to be able to cable it easily and also switch on / off and plug in easily - this was the best position i could find - the driver seat is slid right forward in this photo - in its normal position, the seat is at the rear of the runners and the inverter is pretty unobtrusive TBHThanks
