Blue Knight
When I told my ins about the EP levellers they said keep the receipt in case of an accident and they would know how much it cost me in case of a claim.
John.
Cheers John
John.
For those that have fitted one of these kits how easy would it be to reverse the process and re-install the factory standard rubber bungs ? or are these damaged when you take them out ?
I ask as I couldn't get mine through it's MOT here once I've added such a kit so would need to switch it back before inspection.....
On what grounds would this be an MOT failure?
I think he's referring to an overseas MOT equivalent - not a UK test
He lives in Lausanne?
............. except I don't have the little bit of paper and stamp saying it's approved
This is for my own learning but what approval paper/stamp do you require and to whom must it be presented.
The only reason why I ask is that the VB-Air Maunfacturer supply numerous compliance certifications with its products. I will have to dig them out to clarify the exact contents and fitting caveats etc. I'll try and read them tomorrow.
All the best,
Andrew
Check with on line suppliers whether the kit comes withapproval certificate. I fitted a Dunlop kit from www.marcleleisure.co.uk this came with Dunlop certificate of conformity. Can't remember current price but approx £300. Dunlop Suspension is a Dutch based company. Worth speaking to as their kits are OEM approved.
Yes I should have been clearer.
I've checked and I can fit a DIY air suspension but it can only come from 2-3 specified suppliers that have "approved" kits ie the same ones but from the camper car shop that are 3 x the price..... It's a way to force people to get it done at the shop and spend a small fortune, fully fitted it costs around £1500 here (same type of kits as in this thread) DIY off eBay £300 = no brainer except I don't have the little bit of paper and stamp saying it's approved. As my first MOT is due in a couple of months I can do it after that, then the next one is 3yrs away so not to bad to switch it back if it's only a couple of hours work.
Thanks to all
If you fit it will it affect your insurance cover/road legality?
Thanks to all
My understanding is that their should be no contact when stationary. If their is contact then suspension movement is restricted to the amount of deflection ib the bump stop.In the op it says the bup stops should be clear of the springs if in good condition Im sure I saw a post on here a while ago saying they were supposed to be in contact just wanted anyone looking not to get worried thay were a problem whan not
I decided to buy the VB following your post John, like you after a fair bit of research they probably offered the best kit for the money.I was going to buy the cheaper air kit from EBay but I was informed by Mick from SAP that the air bags with the VB system were better quality than the cheaper kits.
Also I had VB fitted on our last van by the dealer and I was pleased with it.
The only problem that I had was connecting the air hose and tightening the air fittings once the air bags were fitted under the van.
I also had to compress the bellows and zip tie before I could get them to fit.
In hindsite I would fit the air hose the same as @Guigsy did in his installation.
The cheaper kits off eBay have 2 years warranty but the VB only as 1 year warranty and the instructions are pictorial only.
John.
I bought and fitted this kit for our Peugeot/Ducato chassis wich came with an onboard air compressor so I can inflate/deflate the airbags on the move if necessary.
I came via an eBay seller at £315 delivered. Took a morning to fit and plumb in the kit.
I preferred to have the dials and compressor controls to hand so bought a small mounting panel from Marcle Leisure.
I don't have air gauges on my system - VB semi-air. Can I add gauges on to the existing inlets so that I can monitor the pressure? If so, any advice as to which gauges I could use?
Perfect, thanksYou will find most if not all of what you need from these people. I am no expert but I would have thought if you cut the air pipe to the bellows and put a tee piece connector in. A short bit of pipe to the gauge it should suffice.
