Coolcats
- Jan 24, 2019
- 6,464
- 11,727
- HymerCar Ayres Rock
Nice Fan, looks like that will keep everything coolYes, it was the one that came with it. Quite the noisy little bugger it was.
The new one is still a bit loud at full tilt but nowhere near as annoying.
These are verging on the silent when you use the speed reducing kit.
This is the fan I have in now to replace the hs/fan that came with it. I would only use this if you have a compact case though. If you have a decent size case go for the one with the biggest fan as the bigger the fan the quieter they are. I am forced into this one by the size of the case, which was dictated by the space available in my van.
Once I get my new accommodation sorted out I will be going for a bigger case and upgrading the hs/fan to hopefully one with a 120mm fan on it. It makes such a big difference especially with the static pressure ones.
There is a similar versions for the Pi...the ice tower, I nearly brought one but not sure my computations will make the Pi get that hot and I prefer the heatsink case with the mini fans to stop me accidentally touching the board
Who would have thought fans would get so techi
