Fiat ducato wont start
Philsmith
Fiat ducato
Fiat Ducato 2004, 2.8. Turned off engine then wouldn't start. No been a non runner for 4 months. Various mechanics with different ideas so far had
Cam belt changed
New Cam sensor
New Crank shaft sensor
Injectors checked
Ecu checked
Keys checked
New fuse box and relays changed
Rail pressure sensor cleaned
Diesel pressure checked.
Run for a few seconds with easy start
Any simular problems getting desperate.
Philsmith Was the fuse/relay box you have replaced the one under the bonnet as it seems ,if so ,( as long as my information is correct) on the x244, there are fuses in it listed as for - Engine start blocking system = F16 7.5a and Engine immobilizer system +Engine control unit = F18 7.5a , there is also a relay R9 shown for engine management . All of which would be worth checking .
A 12 volt feed to the fuel shutoff solenoid needs to be established, if it has this its the solenoid, if not its an immobiliser or wiring fault.
This is the "crash" fuel shut off, on the bulkhead next to the battery
Powerline Services in Shipley are Bosch master technicians.
They sorted an issue on my x244 that another so called expert had cocked up.
Had a problem once with a hgv same as you tried numerous fixes turned out the breather in the fuel cap was blocked causing a vacum truck would run for a while then cut out maybe worth trying running with fuel cap of
