motorhomer
- May 17, 2008
- 680
- 419
- Van Conversion
- since 2005 (but 30 years caravanning)
True. I found it easiest to see by moving the wider arm to a vertical position. You have to switch on the ignition, then the wipers, and then switch off the ignition when the wiper arm is vertical. You should then be able to see a very small drain hole which is similar to the one on the left.Yes, but it is extremely difficult to see, the windscreen wiper partially obscures is, look close to the wiper pivot and you should see it. Failing that, remove the panel above the light, 2 screws, and then carefully 'wiggle' it upwards to free the pop studs. The panel is plastic and can snap.
The scuttle drain pictures above are of the main scuttle drain.
I have found the 2 small drains get blocked very easily and need probing with a small wire - I use a curtain rail.
