Hutchweb
Symptoms only when engine fully hot, 9 o'clock on the temp dial.
Driving and acceleration is great.
However when it is hot coming off motorway and stopping at lights, light grey smoke billowing out, then smoking badly with light grey smoke when accelerating away.
Like a switch has been flicked, it will then be very smokey on acceleration.
Stop for 10 seconds and as it pulls away clouds of pale grey smoke which then stops after a few accelerations (it is now getting worse and smoking most of time if it is hot)
So it is like the fuel flow is not switching off.
Engine breathing checked
Injectors checked and one replaced
Valve seals changed
Block pressure checked
2 bottles of turbo cleaner put through the turbo
There does not appear to be an EGR
Engine has only done 53000 miles, 2.3JTD 2004, Fiat Ducato
Van is used regularly, we at a loss where to go with this problem now, anyone any ideas?
Valve seals changed
