- Jan 23, 2023
- 228
- 225
- Burstner Travel Van
- Newbie - bought first MH 11/03/2023
Magic rafter pro is better. Eliminates most of the flappage. Much bulkier though.Tie down kit ,used with a magic rafter. works a treat
What's a magic rafter please?Magic rafter pro is better. Eliminates most of the flappage. Much bulkier though.
Fiamma sell two types of brace to stiffen up their canopies. The Magic Rafter is an telescopic bar that hooks from the middle of the awning box on the van, run perpendicular to the van, outwards to the middle of the awning edge. It's reasonably effective at reducing flex and is compact.What's a magic rafter please?
I've found a centre rafter and an additional front panel made a lot of difference to the flapping, and in addition to the tie down kit (which I've always used) makes the whole structure much more secure and stable.They will keep the front of the awning down. They won't stop it from flapping and creaking.
Same here with a thick bungee.I use two of these dog lead anchors and clip the ties on to the rings, and we don't even have a dog!
My new awning is an Omnistor not a Thule by the way. My mistake. As I said, I prefer the Fiamma because of the curved rafter.The big benefit of them for me is the quick release clips. I once got caught in a sudden storm in southern France with the awning out. We had four adults clinging on to the front bar, the fabric was flapping like mad, it took all of us holding onto it. In a brief lull, I was able to unclip drop the webbing and quickly roll the awning in. That £20 pounds spent saved hundreds if not more. My present Thule set is no comparison. Thin webbing, meagre little pegs etc, gives me no confidence at all. I intend to buy another Fiamma kit. And also, I agree about the curved rafter. Brilliant bit of kit, one of my best purchases. Shame it got nicked with the rest of the van. I don't think you can get one for the Thule.
Sounds painful!!I use a pair of flourescent yellow ratchet straps, 2 14 inch pegs and the best part a pair of fabric anchors that slide into the channel of the awning. They stop damage being caused to the knuckles at the top of the legs
Correction!Fiamma sell two types of brace to stiffen up their canopies. The Magic Rafter is an telescopic bar that hooks from the middle of the awning box on the van, run perpendicular to the van, outwards to the middle of the awning edge. It's reasonably effective at reducing flex and is compact.
The Magic Rafter Pro is a brace that runs between the dog-leg shaped arms of the awning. It runs parallel to the side of the van. It braces the awning arms and elevates the canopy material. It's significantly better at bracing the awning and reducing flap. But it's also bulkier and more expensive.
The main thing is to make sure you can tie the awning down. Anyone who thinks they can rely on a few pegs in the awning legs is asking for trouble. The fiamma pegs are probably ok in the nice soft ground of a UK campsite but if you go to sunnier climates the ground will be rock hard so you will need something more robust than the pegs supplied. I've tied our awning up to trees, lamp posts, boulders, basically anything that is not going to move. The safest way to preserve your awning, however, is to wind it in if the weather looks bad.From Funsters experience - is it worth buying a Fiamma kit for £24 to secure your awning?
Or just buy some cord and tie it on to whatever comes to hand?
.... and the best part a pair of fabric anchors
We have the Peggy Pegs kit too and think it's a great system. Plus their foot anchors are way better than just pegging the legs down by the feet: you can use more pegs and it's quick release in case you need to take it in in a hurry. Plus you only have to peg it down once: just leave the foot plates in place when you wind it away, and slot the legs back in when you put it out again.Unless you ordered already, I'd recommend having a look at the Peggy Peg kits - easy to fix to the awning and comes with various pegs or bolts to be used depending on what you're parked on which can be screwee into the ground using a cordless drill. Decent price as well, believe we paid around £80 for ours, worth every penny..
I picked mine up at the lillypad leisure stall at one of the shows. Parrotsol on ebay do a similar oneWhere did you get the anchors from please? I've seen the ones for hanging clothes etc but suspect they are not strong enough for the tie down aspect ...
