PJGWiltshire
Good luck with the advise you have received. You make mention that the system was installed by Van Bitz back in 2005. As you say the cabling you would assume would be correct upon installation and you have fitted new batteries. You are going back into the workshop at the end of the month. Is that with whom you bought the vehicle. My experience is unless something is obviously broken the answer will be" you are plugging in to much' I suggest you contact Van Bitz. It maybe that your inverter MAY need upgrading to accommodate your new add on bits that need power. If your batteries are in good order it could be that you are simply drawing to much. All is not lost. A way round additional power could be the installation of a Stirling B2B charger. This will recharge your leisure batteries quicker. We have one installed and also use this as a form of mini generator. When requiring items that draw a high load I start the engine and wait for the B2B to engage and then turn on inverter for the heavy task in hand (normally running good ladies Dyson hear dryer 1500 w and also to help batteries with the toaster. That way my batteries do not power down as the B2B produces sufficient to assist the batteries. This has been used a lot in these shorter days and lower sun in the UK when the solar panels struggle to keep up with charge into the batteries .
