Fan Resistor (2 Viewers)
antprice1970
242
124
Cheshire, UK
Bessacarr E635 2008
Newbie
Hi all, can I ask if you think this resistor was only 9 months old. It was replaced end October last year whilst under warranty and has stopped working again. Only numbers I can make out are 12/15 on green part. Do they deteriate that quickly?
Thank you
Anthony
Oct 14, 2007
4,202
6,888
Rochester
Auto-Trail Mohawk
17 fun filled years
The fuse goes if it gets too hot normally. It's a common problem and when it goes the fan runs on one speed only, just changed mine in the car.
antprice1970
antprice1970
242
124
Cheshire, UK
Bessacarr E635 2008
Newbie
Yeah it's only working on no.4 so definitely resistor but does it look only 9 months old. Was changed under warranty but I'm not sure it was a new part?
Thank you
Anthony
antprice1970
antprice1970
242
124
Cheshire, UK
Bessacarr E635 2008
Newbie
Does look a bit shabby with signs of corrosion. Is water getting on to it in some way?
No water all dry under there, I suspect dealer has replaced it with second hand part, just thought I'd ask as I would not imagine it would deteriate that quickly????
Thank you
Anthony
5,640
90,882
EAST ANGLIA
Murvi Morello
Since 1975
Thank you
Anthony
I changed my heater fan one in the passenger footwell about 6 yrs ago on my X250 Ducato from a kit I got from Maplins (I think) so no, they don't go that often?
Did you replace the cab filter at the same time as this is advisable? 🤔
antprice1970
antprice1970
242
124
Cheshire, UK
Bessacarr E635 2008
Newbie
Hi, I haven't changed it, it was replaced last October by motorhome depot as it was still under 3 months warranty but it stopped working about 4 weeks ago, only just taken it off to order a new one.
Thank you
Anthony
24,593
143,086
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
I'd also check that the intake to the fan is not blocked with leaves which is the usual problem why they overheat and fail.
antprice1970
antprice1970
242
124
Cheshire, UK
Bessacarr E635 2008
Newbie
It does look a lot older than 9 months.
Hi, yes I think so too, does not surprise me as motorhome depot sold me my motorhome with 13 years old tyres and when I contacted them the lady there said its not illegal and won't reply to me now.
Thank you for your reply
Anthony
1,962
3,292
West Yorkshire
EuraMobil Activa 820HS
Common problem. Mine went whilst enroute to Spain one year in heatwave temperatures. Blower would only operate on one setting and that was intermittent. I ordered a replacement via Amazon and had it delivered to the site. Relatively easy fix.
If you’re stuck, I’ll try look back for the part number.
antprice1970
antprice1970
242
124
Cheshire, UK
Bessacarr E635 2008
Newbie
Thank you for your reply. I took old one off today was very easy just contacted auto company to order OEM part.
Thank you for your help 👍
Anthony
2,628
3,640
KT15.
Sunlight. T66. 2019.
Absolute beginners.
Anthony
Won't the failed resistor have a one year warranty on it, being a new replacement?
Mike.
antprice1970
antprice1970
242
124
Cheshire, UK
Bessacarr E635 2008
Newbie
Mike.
Hi, I'm not sure but warranty was only for 3 months but I'm not sure they replaced the resistor with a new one. It was replaced October 2023 by motorhome depot but when I removed it yesterday it was rusty (as pictures). I can't make out writing on the resistor but can make out stamp quoting 12/15, if that's month/year not sure but wouldn't be surprised because they sold me motorhome with 13 yr old tyres.
Ordered a new one today.
Anthony
6,204
11,816
Birmingham, UK
A-Class
Check the wiring harness too. The socket it plugs into often gets toasted and causes further failures. The resistor pack is often sold with the connector and wire tails to patch the replacement back in.
I think mine failed because my wife is a serious fidget. It's actually fairly easy for the passenger to kick the connector and short it out.
antprice1970
antprice1970
242
124
Cheshire, UK
Bessacarr E635 2008
Newbie
Thank you
4,631
10,324
South Lincolnshire
Rapido 7065+
Broken most bits now
Thank you
Anthony
Could well be only 9 months old. They sit in the wet cold air drawn in by the heater so rust very quickly. They're only a fiver off Temu so I doubt they would bother trying to source a used one.
