Fan heaters
When tenting in Spring / Autumn I used a small ceramic fan heater. Most had two settings for arund 900W or 1800W. 900 was usually sufficient for the space of a 3 man tunnel type tent once it had been zipped up. Thermostat could be set so you could keep the chill off without it needing to run incessantly. Switch on the bottom meant it would cut out if knocked over. Something like : Amazon product ASIN B009NQRDWA
Obvious concern would be whether trying to run this, even lower wattage, at same time as heating in a MH will overload your supply. As others have said Greta isn't going to like you and many sites will take a dim view of trying to heat the awning.
Tell us please where do you get your super cheap electricity from?
It has gone up 2.5p since I checked!
