Exhaust heat shield / double skin (1 Viewer)
Jan 31, 2016
1,123
608
Halifax
A Class Rapido 9097F
June 2016
Would you say I could just cut this off?
Would it still pass an mot?
Or will I need a replacement part
Looking at it don't think box will last long as part of it already looks corroded
It's 2008/2009 Fiat ducato 2.3
Will a replacement be easy to source?
Seen some horror stores in getting exhausts
12,439
50,647
Cornwall
Ducato PVC
Getting Better
As it happens I have this exact problem too, I spoke to my garage people and the mot chap said just peel it of, they have two or more skins and is not an mot failure unless it’s blowing…
Feb 9, 2008
4,163
6,098
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
Mine lasted a year after it started to peel, then it failed quite catastrophically on the road. Perhaps it's time to fit a new exhaust?
zac
2,753
1,995
Basingstoke
Rapido A CLass 10000
since 2013
i removed mine (heat shield) as it was falling off and it passed the MOT no problem, mine's a 2017 fiat base for info.
Apr 22, 2018
7,238
13,275
Herts.
Adria Coral lowline
That is the outer skin of the silencer. Just remove it and it will pass MOT as long as it’s not blowing.
It looks from your photo to be a standard exhaust for a Fiat Ducato van. There are two types and the difference being how and where the pipe leaves the silencer. Often this pipe is then cut with a different end to alter it for motorhome use.
