EP Stabilisers making a whirring noise
bury st edmunds
Boxer Peugot 2001
newbie
Hi Guys,
I am having a whirring noise and shaking of the van, that I think is the EP STabiliser?, It happened initially whilst I was stationery, An Almighty jet noise, and shaking of the van happened, and lasted for about 10 minutes.
It stopped, I checked around the van, and thought it might be the pump, as I was in the shower when it happened.
What I am left with now, is everytime I put the electronic screen on after parkup, to see about water and voltage etc, the same noise intermittently happens, for about 7 minutes, it rattles through the van, like the stabilisers are trying to find a solution, but the large struts are alrelady down in place.
So far, in the 3 weeks the stabilisers come down and go up without a problem, but the intermittent noise comes on instantly, when the screen is put on!
It is slightly disconcerting, as I am worried that one day I put them down, and they might NOT come up again? So far this has not been a problem, but the noise is a Worry ?
I live in Suffolk, and now have to find a garage that deals with this particular model, and the nearest is Peterborough I see?
I am now reluctant to use the MH , due to the constant worry about the stabilisers HELP please
Caroline
Why don't you post a thread asking if there is an experienced funster in your area that could come over and take a look at your van ?
Hi Andy
so kind of you to suggest this, but I've had a engineer out to fix my loo, which he stillis having problems with the Dometic system leaking through the pull leaver ! grr, new porcelain bowl new rims and 10 hours of labour, and theleak is still coming out of the pull leaver. so he has suggested I keep pull lever out, and Dont use the lever mm
Anyway, I asked him to listen to the whirring , he instantly disconnected the Satelite Dish, and Guess What ? Whirring completely stopped ! hahah Hurray ! When I bought the van in august seller said, he only used the Hotspot as he couldn't get the satellite to work, so that is what I've done. But when you put the control panel on, the Aierial, seems to whirr and whirr around, making a loud vibration and noise through the van, so at least now I know it isn't the ESP as that would be very expensive ! Phew, thanks fo the suggestion though Andy,
