Hi all,
Do you use engine braking in your motorhome? I find myself using it a little from time to time and I suspect it's frowned upon by HGV instructors... but I've never had any instruction so I'm curious. I'd never driven a big diesel before last month. I've done the IAM motorcycle advanced test and they have a saying - brakes to slow, gears to go. It basically means that you shouldn't use engine braking. They also advise block-changing - changing to the gear you want all in one go, rather than changing one gear at a time and declutching between. And not changing gear at all until you've finished braking. It all depends on circumstance but they are general guidance points.
I try to drive my MH at a very leisurely pace - but I'm still occasionally tempted to use a little engine braking - for example, as I'm entering a roundabout with a little more speed than I'd like to carry round and the gear I want will give some braking.
I realise this might seem a bit 'who cares' to some but I've found myself wondering and so thought I'd see what people think... I suppose the important question is this: can gentle engine braking cause any mechanical issues?? I wouldn't have thought so...
(let the disagreements commence)
