Engine battery. (27 Viewers)
Apr 7, 2024
37
39
2017 Renault Master
Hi guys,
I was wondering how you keep your engine battery topped up over winter?
I have a mains powered trickle charger which I can connect to the battery by either croc clips or buy one of these type of connectors
However I can’t see a means of having this easily placed where I can get to it without it getting too weathered.
So I was just wondering what you guys do?
The battery on the Renault Master is under the passenger side seat/Step and has about 6 bolts holding the cover on so not just a quick case of popping on and off.
Thanks.
Jan 19, 2014
9,915
26,412
Derbyshire
Elddis Accordo 105
since 2014
I've got the SAE tail on my engine battery, it's got a cap on it and it's just loose on the floor near the passenger seat legs. At home I plug an optimate maintainer in.
5,096
17,950
Todmorden
Van conversion
FUNSTER in a PVC
Battery Master from Jim or Vanbitz which should trickle charge from your leisure battery 👍🏻
167
221
Somerset, UK
Buerstner Travel Van
Not long enough!
Solar panel + Battery Master + EHU on a time switch giving a few hours charge every Sunday. Without the EHU the starter battery loses charge during winter (virtually no use + no sun + alarm drain).
1,765
1,817
Swift Suntor 590RL
Solar and Battery Master keeps my lead acid starter battery and lithium leisure battery both fully charged over winter.
Speedytriple
Apr 7, 2024
37
39
2017 Renault Master
Thanks for all the ideas guys.
I have solar on roof but I don’t think it’s hooked up to the engine battery.
I do have a jump start terminal under the bonnet so that’s a good shout actually.
Cheers.
