Paul, we had an 2013 Autograph 740 and I fully sympathise. They may have changed the design since then, but we found that if you line the tap up correctly you can pull the tap unit off (making sure the waste tank is empty, first, of course!). Then looking up the waste pipe on ours, there was an insert which blanked off half the diameter of the waste pipe. This insert was easy to pull out, and the result was a larger pipe - still pretty slow to drain, but no longer quite as embarrassingly glacial.
This mod was quite widely discussed at the time, so the fact it apparently no longer is may suggest Bailey have found other ways to make the waste system so painful! I seem to recall someone suggested the insert may have had a purpose - I can only say we never had any problem arising from it’s removal.
Sorry I can’t remember the full details but it was some time ago.
