So you are missing out the RCD and using a 2.5mm cable with a 13 amp plug on each end. You must be mad. The whole idea of the RCD is to protect the inhabitants of the MH when using 240v electricity. What you should do is connect the house electrics to the proper 240v inlet on the MH. You should also remember that if you use a generator you will be powering the whole MH including fridge and battery charger. I would have thought that the RCD in the house is not happy finding another RCD connected the wrong way round which is what you are doing. You are supplying 240v to the output of the RCD. Just do it correctly before you KILL SOMEONEand it you don't know what you are doing LEAVE IT ALONE ...
Notwithstanding the fact that his intent is inappropriate, you are missing the point of his approach. He was intending to to feed his generator supply to the input of the distribution box, thereby trying to retain the protection afforded by the RCDs to the onboard 240V supplies.
Ian
