- Feb 27, 2020
- 450
- 818
- pilote diamond 783
- 2 years
just as a point your inverter has Built-in Network priority circuit with voltage synchronisation which I believe means your inverter stays switched on and (subject to your remote switch ) which means the inverter kicks in when the ehu is removed, obviously this will only run to the capaity of the source battery/s and the low voltage cutoff so this is why your power runs via your inverter it does not mean your inverter is running when you have EHU only when its removed if i am wrong someone chip in. This does not help with your error code just to explain why via inverter
