- Aug 18, 2014
- 26,610
- 162,798
- Transit PVC
- 16 years since restarting
The 3500kg version has a payload of 690kgs with the big battery pack . & all of this does not include optional equipment.Interested in payload. I wonder what the empty weight of an electric Ducato van is?
Tony
The 4250kg version with the smallest battery pack has a payload of 1885kgs . Which appears to mean that the "big" battery pack weighs an additional 445kgs, if my maths is correct.
It would only be in using one as to see what range would be possible with smallest battery in largest vehicle-
HERE;
https://www.parkers.co.uk/vans-pickups/fiat/ducato/2021-e-ducato-dimensions/
*** Oh & you cannot tow with either of them .there is no towing capacity
I can run for nearly 700miles before filling. I fill & can run the same distance again inside 10 minutes.This is the major problem for me.Not being able to refill/recharge in minutes & completelyWe can recharge at the equivalent of 1000 miles / hour, so 15 mins will add 250 miles on a good charging poin
They do.Ford pickup has outlets in the bed just for running equipment. The bloke I watch in Idaho knew his was useless for 6 months of the year regarding mileage,towing & the low temperatures but wanted to see how it would work running his off grid workshop & apartment from the bed sockets.It works far better than the vehicle is useful for as a means of transport in the winterI can't imagine many manufacturers doing that though, for a start I doubt the base chassis manufacturers would allow it and secondly the habitation manufacturer won't risk you running down the traction battery to the point you can't get to a charge point, or even move off your wild camping spot.
