I’d offer the same infoThey were linked to the parking lights on our old Bessie. Did you perchance turn the ignition off while the indicator was still selected as that will set the parking lights. Try starting her up. Lights on, lights off, ensure indicator stalk is in mid position, then turn it off. Does that clear it?
And again in English.Pulled up at campsite and can’t turn off orrange eunni g lights or 2 lights at friends t top of Motorhome. No other lights are is except awning light. Really dot understand. Also Alde panel stopped working
Help
Steve
Thank you but lights still on. Tried everything I could think of??They were linked to the parking lights on our old Bessie. Did you perchance turn the ignition off while the indicator was still selected as that will set the parking lights. Try starting her up. Lights on, lights off, ensure indicator stalk is in mid position, then turn it off. Does that clear it?
Yes on EHUAnd the exterior marker lights are still on?
Never had an Alde so can't help with that. Hopefully someone with that experience can help. Out habitation fuse panel on the Bessie was let into the wooden panel right behind the drivers seat. If yours is in the same place, then slide the seat right forward. You should have a fuse layout in the manual so can check ( hopefully with a multimeter) the fuses that may be causing the problem. Difficult in the dark. Are you in EHU?
Hi, Thanks again. I found the Habitation fuse panel which also described which fuse was which. I pulled the awaning fuse and the marker light fuse. The Awning just went DIM as did the orange marker lights. The 2 roof front marker lights just stayed fully on and are still full on. I am with dealer Monday as fed up to teeth with this motorhome. Its only 13 months old and spent more time in workshop than on holiday. Appreciate help and adviceYes on EHU
