mitzimad
- Jan 28, 2008
- 10,327
- 18,889
- Renalt burstner
- 7 years campers before that
you can buy full bore lever valves they are more expensiveIf you are still looking for a lever these are excellent:
http://rover.ebay.com/rover/1/710-5...0001&campid=5338547443&icep_item=152456432777
You need one bigger than the nominal pipe diameter because the hole through the ball is smaller (than the nominal pipe size).
tmplumbing.co.uk/pipe-fittings-c433/compression-valves-15mm-28mm-c41/jtm-compression-valves-blue-handle-lever-ball-valves-full-bore-wras-approved-p10220?gclid=Cj0KCQjwgNXtBRC6ARIsAIPP7RvLtco2rOQq8MF7bawgIFIFqyQdgsBZBzU3FcqgtOH1oRn0wesK1EsaAuGREALw_wcB
