Ah, PS276 is single output PS306 (in mine) is dual output.Go on then, explain to me why the Victron needs to be both a PSU and a charger when the original PS276 or PS306 are not both?
Surely that's one to the cab battery and one to the leisure battery (6A & 20A).They have two outputs- one to the PDU and one to the battery.
No, see Beekeeper's explanation above, although my van has a B2B charger for the leisure side.. The solar charger does have two battery outputs though.Surely that's one to the cab battery and one to the leisure battery (6A & 20A).
The BCA information states the yellow/black two pin output is the three step charger output of 6A to charge leisure battery. The red/black wired two pin output supplies the 12v system directly when on EHU. No mention of vehicle battery which is therefore charged via a split charge unit which Shortap mentioned in previous pos.t
Sorry, thought you were talking about the controller output side. On the solar panel side, no need for a fuse at all, there are no circumstances in which a solar panel could blow a fuse that is big enough to carry its normal output. But may be useful as a handy means of isolating the panels when working on the battery, for example.Solar panels wired series and parallel so supply 24 volt input ,so half the current a 12volt input would be at same wattage. So half of your 40amp suggestion, hence 20amp fuse.
It's an 'offline' charger. The motorhome loads are supplied by the 20A PSU, and the leisure battery is charged by a 6A 3-stage intelligent charger. There should be some automatic switching that disconnects the leisure battery from the motorhome loads when the EHU is plugged in, and reconnects it when it is unplugged.Theory or a fact?
Remember it's how Elddis integrate the BCA PDU into their electrical system that determines what the BCA PSU outputs to.
Could I have a copy of the wiring diagram, please.I have a schematic wiring diagram of the BCA PDU which I got from BCA technical when I was diagnosing a problem we had and I'm more than happy to PM this to you if it will help you.
Who makes the wiring harness ?It's an 'offline' charger. The motorhome loads are supplied by the 20A PSU, and the leisure battery is charged by a 6A 3-stage intelligent charger. There should be some automatic switching that disconnects the leisure battery from the motorhome loads when the EHU is plugged in, and reconnects it when it is unplugged.
But I wouldn't be surprised if the person wiring it up has got it wrong, and wired it like the single-output version of the charger. The wiring diagrams for the two chargers will be different, does it mention the PS306 unit specifically, or just the PS276?
I know it might be different to the version used in Bailey MH's but it will give me an idea as how the cables connect to the circuit board.
Hi, I'm just catching up on this thread from last week. I've been trawling through the cable routes and what I've noticed is that Elddis (mines the Marquis Majestic version to the 255) loom seems to be a basic one for certain models with "add-on" harnesses that stretch out the wiring to accommodate the longer vehicles and (most probably) to cover additional features. I found a label on a connector in the cavity in the drivers B Pillar, where the base vehicle would have a fuse box for the rear compartment; this read "Explorer Majestic Encore 255", hence my assumption about the add-ons (Explorer seems to be division of Ernest Hymer/Elddis). Plus I have battery leads from the PDU which are extended by 2 sections that have M/F connectors (the 255 is 7.4M) and a couple of other branches that go nowhere.Who makes the wiring harness ?
I know BCA make some harness's, but whether it's a BCA or an Eldiss is the question.
Yes absolutelyOK if the PS306 is a psu & hab battery charger, can I just disconnect the 6A output and add a battery charger - connected directly to the hab battery ?
Thinking of using a Victron BluePower Charger 5A.
A more cost effective solution than the Apuljack replacement @ £250.
I think there's a misunderstanding here. How I read that info from Apuljack is that some motorhomes have a switch on the distribution panel that sends the EHU charging power to either the leisure battery or the starter battery, the user can choose.I was going back over correspondence with Apuljack and realised that I may have missed an important comment relevant to this discussion (ref the underlined);
"the AE276-L is a single output unit, so it will charge the leisure battery, however in many vehicles this output runs through a distribution board which switches the charge to the starter battery as required."
I will follow this up with both Erwin Hymer and Apuljack and if this also allows the engine to charge the leisure battery when in transit (other vehicle models are available). I have some more testing to do now I have Two on Tours Cct Diagram (many thanks) and will investigate this further.
Thanks autorouter. I can't vouch for those that may have a manual switch as I don't have one, plus the cct diagram I received shows relay controls, therefore it is an automatic switch over and indeed that is how the system has been operating from new. In installing my upgrade I was keen to keep as much of the original functionality as possible. I now believe that the Tyco relay unit on the starter battery -ve Bus provides that switching control. That said your comment is useful in providing a broader understanding of the system configurations out there.I think there's a misunderstanding here. How I read that info from Apuljack is that some motorhomes have a switch on the distribution panel that sends the EHU charging power to either the leisure battery or the starter battery, the user can choose.
Sometimes the same switch allows the habitation 12V loads to be switched between the leisure and starter battery, for 'emergency' use. Not something I'm very keen on but I think some like the idea, especially ex-caravan owners I think.
I think you have in mind the 'split charge relay', which is usually built into the distribution board, and connects the leisure battery to the alternator/starter battery automatically when the engine is running, so that the alternator can charge both batteries. The split charge relay is switched on by a 'D+' (engine running) signal from the alternator.
The D+ signal also switches two other relays, the fridge 12V is turned on and the habitation loads are turned off when the engine starts.
BCA Seattle control panel allows this - membrane switch and option on graphic display.Sometimes the same switch allows the habitation 12V loads to be switched between the leisure and starter battery, for 'emergency' use. Not something I'm very keen on but I think some like the idea, especially ex-caravan owners I think.
I'm trying sort this out myself so this may be of use; Erwin Hymer sent me the attached diagram and explanation.So went into motorhome switched on master, nothing came on . Panel said master on, lights on , but they weren't. Heard relay switch in PDU. Plugged in EHU and it all worked. Unplugged EHU , lights went out. Awning light worked ok. I noticed radio stayed on when ignition switched off. So I plugged the yellow/white wires from battery charger back together and system works again . Obviously something to do with d+ signal, but why should the charger output effect this. Maybe I should try disconnecting just one of the charger output wires. Any suggestions folks! I tried inverter to power a hair dryer and that works as it should pulling 129 amps.
