I need to replace our socket as the flag is knackered . Looks a simple enough job to me . Should I switch off the fuses etc before ? Any other tips welcome
No need to isolate or disconnect anything....Just change it.
Ensure you reconnect the wires the correct way round.
Remove the socket and photo the back before removing wires to assist refitting.
Well if you are changing the plug, obviously the mains supply will be disconnected.No need to isolate or disconnect anything....
Except may be the incoming mains supply![]()
Changing the socket on the van side, not the plugWell if you are changing the plug, obviously the mains supply will be disconnected.
Not if U remove the socket U are changing from the rear first or from the body whilst still on ehu...light hearted commentWell if you are changing the plug, obviously the mains supply will be disconnected.
True although I would say anyone who would try and do it without taking off the mains lead will just cock it up some other wayChanging the socket on the van side, not the plug
Well that's what I meant. You cannot change the socket with the plug plugged in.Changing the socket on the van side, not the plug
Yeah, live dangerously....Not if U remove the socket U are changing from the rear first or from the body whilst still on ehu...light hearted comment
Normal waterproof sealant like the rest of the van ?Don't forget some mastic tape or non setting mastic on refitting
Yes but not siliconeNormal waterproof sealant like the rest of the van ?
So, what you are saying is, that the plug on the end of the cable is not, in fact, a plug, but is a socket. Even though this 'not plug' is inserted into the socket in the side of the van.Oh goodee! Semantics - nearly as good as a toilet thread.
One could call the van fitting a 'socket' in that one pushes the plastic fitting at the end of the EHU lead into it.
However, the working guts of the connection is the contact between the metal parts which carry the current. The van fitting contains the 3 pins, which for most other connections are associated with the word ;plug or 'male''. Conversely the fitting at the end of the cabl contains the holes which accept the 'pins and are usually associated with the word ' socket' or 'female'.
So I posit that one could decribe the van fitting as a 'plastic socket containing a 'plug'.
Any advance on that?
Sounds like yes minister!So, what you are saying is, that the plug on the end of the cable is not, in fact, a plug, but is a socket. Even though this 'not plug' is inserted into the socket in the side of the van.
Moreover, you also assert that the socket in the van is not, in fact, a socket, but is actually a plug. In the side of the van. With a flap to cover thesocketsorry, plug, into which you insert theplugsorry, socket on the end of the cable.
But what about the other end of the cable? If the socket end goes into the van plug, then the mains end must plug (or is that socket?) into the EHU socket. Or is that a plug
Just clarifying![]()
Yeh, socket it too himSo, what you are saying is, that the plug on the end of the cable is not, in fact, a plug, but is a socket. Even though this 'not plug' is inserted into the socket in the side of the van.
Zzzzzzzzz!Any advance on that?
I can't believe it's not butter - Alice TinkerSo, what you are saying is, that the plug on the end of the cable is not, in fact, a plug, but is a socket. Even though this 'not plug' is inserted into the socket in the side of the van.
HiNot if U remove the socket U are changing from the rear first or from the body whilst still on ehu...light hearted comment
Hi MrNobody has mentioned that you will need to use a screwdriver. There are several types of screwdrivers so you may need to go out and buy a completely new set.
You also need a couple of mains testing devices. One of the type that plugs in to a socket so you can test each socket in the van after completing the task, though it can't be used for the socket you're replacing (even if the socket is a plug, as has been pointed out), and a pen type device that allows you to check if you have 'power' by touching the cable.
The plug in device will also tell you if you have crossed/reversed polarity, of which others may be able to offer further advice. There are lots of threads on reversed polarity so I suggest you sit down and do some research for a few hours, making sure you keep your fluid levels high during the research period.
There may be a need to extend the cable inside the motorhome if the existing cable is not long enough to be able to make the connections. The existing cable ends may look all dull and you may prefer shiny copper so you may have to reduce the length of the existing cable. In which case you will need more cable and a set of wire strippers. These strippers are different than normal strippers and are usually a lot cheaper
A multimeter might be needed at some point either during the install or for some other related matter, so perhaps it's worth purchasing at the same time.
I haven't mentioned rubber gloves for additional PPE as I have very little knowledge in selecting the correct level of PPE that may be required, hopefully someone else may be able to offer detailed advice.
i did think about the yellow vest syndrome, it seems it makes everyone who is wearing one always correct in whatever they do or tell others to do or not to do ..... and can only be 'trumped' by either a yellow vest wearing clipboard holder or the ulitmate 'vesty', a fluorescent pink one ....Hi
Love it ..... " .light hearted moment " ............... or...... FRIZZY HAIR TIME !!![]()
Tea Bag.
Hi Mr
Would it not be easier to make electicity...Visible ?...... Wear a Yellow vest ? Talking as someone who has been BITTEN by leccy when not ready !!.>
Tea Bag
From Darwinian principles that might remove them from the gene pool though...True although I would say anyone who would try and do it without taking off the mains lead will just cock it up some other way
Got a link? Mines broken too!LOL I’ve ordered the replacement and fitted it quicker than this thread has finished . Very easy
