No I'm not missing the point. The point is that reverse polarity doesn't matter if all the protection devices are double-pole. A fuse is single pole. If a single-pole protection device is on the neutral wire, it will not isolate the device if there is a failure, so some danger will remain. That's why normal house-type single pole MCBs are not allowed in motorhomes and caravans, and double-pole MCBs are required. I agree that in a motorhome which doesn't have a 32A supply, the fuse is largely redundant, at least the 13A one is anyway. If there was a commonly available UK plug that didn't have a fuse in it, I would recommend fitting that. But there isn't.I think you are missing the point here. They are not designed so they are only safe with the correct polarity. As you rightly say, they need a fuse because they are designed to connect directly into a 30amp circuit, and their sole function is to ensure that 30 amps cannot pass through the lead to the appliance or the appliance itself, which would probably result in a fire or severe damage to the appliance. While a fuse is, as you say, a single pole protection device, that really doesn't matter, as a fuse can be anywhere in a circuit and still function correctly.
